Home > Maintenance & Modifications > Replacement seat belt parts!
sconie
Hi all, I'm looking for advice on sourcing two seat belt parts for my upcoming mot.
The first is my front passenger side seat belt as its been damaged by the door lock. Aftermarket will be fine as the originals look pricey.
The second is the centre seat belt stalk on the second row, as you can see the plastic cover has been broken or lost, I don't think the cover can be replaced and can't see any part numbers? Again happy to consider aftermarket.
Thanks
Hi all
[/img]
Post #868142 18th Nov 2020 3:56pm
kmac
I had to replace my front passenger side seat belt as the Mrs kept slamming the door on it.
Got it from Exmoor trim. Since it comes with the bit you clip into (mine was fine so didn't replace that) perhaps you can use that for the back row damaged one
Exmoor trim sell the aftermarket ones at a reasonable price
One small thing was the plastic cover for the seat belt reel didn't fit on the replacement - I can take the Dremel to it but didn't seem worth it and it passed the MOT without the plastic cover
Post #868198 18th Nov 2020 9:06pm
sconie
That's brilliant thanks, I'll call them to see what part I need.
Post #868211 18th Nov 2020 10:14pm
In extremis you can always remove the seat for the MOT test. It has been done!
Post #868246 19th Nov 2020 8:48am
