Home > Wheels & Tyres (L663) > BF Goodrich All-Terrain T/A KO2 in winter
Page 2 of 3 <123>
ChrisCroft
Its all made more difficult with LR using captive studs in the hub, so you have to jump to a 30mm spacer; often a 10mm/ 15mm spacer is all that's required to get a larger tyre to fit (depending on the catch point).
Post #872730 13th Dec 2020 1:49pm
ChrisCroft
This is definitely the answer you are looking for....... I think
https://www.facebook.com/groups/686273281850563
Post #872767 13th Dec 2020 5:51pm
ChrisCroft
Post #872933 14th Dec 2020 7:35pm
c4skp
Think it's time I move to the ko2.
Wet grass was not the best mix in a wet field track.
Post #873637 18th Dec 2020 6:26pm
ChrisCroft
Oh dear,
Is your current rubber the plain standard LR road tyres?
Post #873642 18th Dec 2020 6:46pm
c4skp
Standard road tyres.
Has scratched the sides of the alloys also, so will hopefully polish out.
The ko2 will hopefully give the rim some protection when in rut.
Post #873659 18th Dec 2020 8:02pm
Digger2000
United Kingdom 2006 Defender 90 Other HT Tonga Green
ChrisCroft wrote:
Cheers Chris Thumbs Up
Post #873878 20th Dec 2020 5:39pm
Cheshire110
Anyone know the offset and width of LR’s 20” wheels (presumably they’re all the same or does it vary by style?) Cheers, David
Post #873983 21st Dec 2020 1:24pm
Simon Audi
I think they are all 41.2mm
Post #873986 21st Dec 2020 1:46pm
nowrxo
Post #874087 21st Dec 2020 9:41pm
Cheshire110
Fab, thanks folks.
So TL;DR...
8.5 in width
41.5mm offset Cheers, David
Post #874089 21st Dec 2020 9:44pm
goodtimes
United States
Thinking about getting KO2s - but question is the full size spare on the tailgate. The KO2s are much heavier than the OE options. Anyone having issues mounting a 5th KO2 to the tailgate?
Post #875803 2nd Jan 2021 12:33am
c4skp
I hang my bike off the spare, with no problems.
Post #875861 2nd Jan 2021 2:06pm
GreenMonster
United States
Keep in mind KO2’s are mountain rated with the 3 peaks which just means they pass some tests in packed snow, but are not the same as full winter tires, especially on ice. Nokian Will apparently come out with their unbeatable Hakk’s next Fall in Defender sizes, but even the Pirelli or Conti winters should be better than KO2’s on icy roads due to softer compounds. Depends what you really need.
Post #875992 3rd Jan 2021 3:28am
SteveG
2005 Defender 90 Td5 CSW Belize Green
If you’re worried about scratching your alloys, don’t take it off road. No tyre size will protect them from stones etc. in ruts.
Post #875995 3rd Jan 2021 7:33am
Page 2 of 3 <123>
