![]() | Home > Wheels & Tyres (L663) > BF Goodrich All-Terrain T/A KO2 in winter |
ChrisCroft Member Since: 28 Nov 2020 Location: Lincolnshire Posts: 9 ![]() ![]() |
This is definitely the answer you are looking for....... I think
https://www.facebook.com/groups/686273281850563 |
c4skp Member Since: 11 Oct 2020 Location: Dorset Posts: 24 ![]() ![]() |
Think it's time I move to the ko2.
Wet grass was not the best mix in a wet field track. ![]() Click image to enlarge |
Oh dear,
Is your current rubber the plain standard LR road tyres? |
Standard road tyres.
Has scratched the sides of the alloys also, so will hopefully polish out. The ko2 will hopefully give the rim some protection when in rut. ![]() Click image to enlarge |
Digger2000 Member Since: 19 Sep 2020 Location: Newcastle Posts: 590 ![]() ![]() ![]() |
Cheers Chris ![]() |
Cheshire110 Member Since: 26 Jul 2013 Location: Cheshire/London Posts: 2770 ![]() ![]() |
Anyone know the offset and width of LR’s 20” wheels (presumably they’re all the same or does it vary by style?) Cheers, David
Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
Simon Audi Member Since: 19 Nov 2020 Location: Newport Posts: 544 ![]() ![]() |
I think they are all 41.2mm
nowrxo Member Since: 10 Sep 2015 Location: None Posts: 79 ![]() ![]() |
41.5mm according to this:
https://www.wheel-size.com/size/land-rover/defender/2020/ |
Fab, thanks folks.
So TL;DR... 8.5 in width 41.5mm offset Cheers, David Land Rovers of all shapes S3 onwards… Daily is a 110 V8. |
goodtimes Member Since: 04 Jan 2020 Location: Greenwich, CT Posts: 29 ![]() ![]() |
Thinking about getting KO2s - but question is the full size spare on the tailgate. The KO2s are much heavier than the OE options. Anyone having issues mounting a 5th KO2 to the tailgate?
I hang my bike off the spare, with no problems.
GreenMonster Member Since: 30 Sep 2020 Location: Virginia Posts: 77 ![]() ![]() |
Keep in mind KO2’s are mountain rated with the 3 peaks which just means they pass some tests in packed snow, but are not the same as full winter tires, especially on ice. Nokian Will apparently come out with their unbeatable Hakk’s next Fall in Defender sizes, but even the Pirelli or Conti winters should be better than KO2’s on icy roads due to softer compounds. Depends what you really need.
SteveG Member Since: 29 Nov 2011 Location: Norfolk Posts: 664 ![]() ![]() |
If you’re worried about scratching your alloys, don’t take it off road. No tyre size will protect them from stones etc. in ruts. |
