![]() | Home > Wheels & Tyres > Can you run different tyre brand on front and rear axles? |
LR90XS2011 Member Since: 05 Apr 2011 Location: bickenhill Posts: 3651 ![]() ![]() ![]() |
yes the centre diff makes up for different sizes, (don't use diff lock on grippy surfaces though, which you should not anyway as the transmission will wind up very quickly) DEFENDER 90 TDCI XS,
yes
tyre are fitted new to the rear and rear moved to the front |
TamarBlue11 Member Since: 25 Sep 2020 Location: England Posts: 226 ![]() ![]() ![]() |
Thanks guys, tyres are pretty similar anyway both A/T and fronts are just worn down alot more.
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17588 ![]() ![]() ![]() |
I've actually been running slightly different front and rear diff ratios for 200,000 miles with no ill effects, so provided the difference is not extreme it will do no harm!
The reason for this slightly odd situation is that I have an Ashcroft 3.5:1 HD ring and pinion in the front diff, but the standard P38 3.54:1 ring and pinion in the rear. Last edited by blackwolf on 14th Nov 2020 3:52pm. Edited 1 time in total |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8162 ![]() ![]() ![]() |
Yes, you won't have a problem unlike some other 4x4s which can need all 4 tyres at once. Cheers
Naks Member Since: 27 Jan 2009 Location: Stellenbosch, ZA Posts: 2652 ![]() ![]() ![]() |
Shouldn't you rather run the new tyres on the front axle, since that's the steering axle? --
2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Front ones are getting changed next week. Tyre garage couldn't undo one of the front lug nuts for some reason! So my job when the rain stops.
