Home > Wheels & Tyres > Can you run different tyre brand on front and rear axles?
TamarBlue11
United Kingdom 2011 Defender 90 Puma 2.4 HT Tamar Blue
Hi guys
Perhaps a stupid question.. and long story why... but can I run new tyres on the back for a week or so on my Puma until the new ones are fitted on the front? They are the same size.
Thanks
Post #867240 14th Nov 2020 8:59am
LR90XS2011
yes the centre diff makes up for different sizes, (don't use diff lock on grippy surfaces though, which you should not anyway as the transmission will wind up very quickly) DEFENDER 90 TDCI XS,
Post #867244 14th Nov 2020 9:06am
dorsetsmith
yes
tyre are fitted new to the rear and rear moved to the front
Post #867245 14th Nov 2020 9:06am
TamarBlue11
Thanks guys, tyres are pretty similar anyway both A/T and fronts are just worn down alot more.
Post #867250 14th Nov 2020 9:15am
I've actually been running slightly different front and rear diff ratios for 200,000 miles with no ill effects, so provided the difference is not extreme it will do no harm!
The reason for this slightly odd situation is that I have an Ashcroft 3.5:1 HD ring and pinion in the front diff, but the standard P38 3.54:1 ring and pinion in the rear.
Post #867272 14th Nov 2020 11:59am
jst
Yes, you won't have a problem unlike some other 4x4s which can need all 4 tyres at once. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #867277 14th Nov 2020 12:33pm
Naks
Shouldn't you rather run the new tyres on the front axle, since that's the steering axle? --
Post #867308 14th Nov 2020 2:24pm
TamarBlue11
Front ones are getting changed next week. Tyre garage couldn't undo one of the front lug nuts for some reason! So my job when the rain stops.
Post #867328 14th Nov 2020 3:42pm
