Home > Series Land Rovers > What rims have I got?! |
Chicken Drumstick Member Since: 17 Aug 2020 Location: Near MK Posts: 785 |
Most Land Rover rims will have a part number stamped on them.
As for sizes, depends what you are wanting to do really. Series rims are 5.5" wide (in terms of bead area). They can fit 7.50 x 16's tyres and smaller. Most tyre makers will suggest a 6.0"j rim for a 235/85R16. So you'd need a 90/Defender rim for this size. Many Series rims are also tubed rims. Which means it is dangerous and illegal to run a tyre without a tube in it. You can ID this on if there is an extra bulge or not on the bead area of the rim. |
10th Nov 2020 11:56am |
v8bob Member Since: 14 Mar 2018 Location: Midlands Posts: 323 |
The ones shown have the rim riveted to the centre, so they are tube type.
10th Nov 2020 2:36pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17559 |
Traditionally rims for SWB models were 5" whilst those for LWB were 5.5" I think. SWBs had 6.00x16 tyres whilst LWBs had 7.50x16 tyres.
10th Nov 2020 3:29pm |
Wheel rim width is measured inside of the two rims so if you've measured what I think you've measured, you have some standard SWB wheels. As v8bob says, they're for tubed tyres.
Some very early models had 4.5 inch wide rims but they're really not very common. Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
10th Nov 2020 9:57pm |
LCJ Member Since: 07 Sep 2009 Location: UK Posts: 201 |
Thanks for all the responses. I posted the same question on the S2 forum and the consensus there seems to be that they are Kelsey Hayes wheels, and most likely for a trailer or other lighter vehicle. Given that and the fact they're for tubes means I probably won't use them on my car, so if anyone wants them and can collect from Haslemere, Surrey, they're free to a good home!
11th Nov 2020 9:28am |
tbh the easiest way for Land rover 'looking' rims. Is to buy some for a 90/Defender. They will fit straight on, are wide enough for a 235/85 and are tubeless. Should also be easy and cheap to pick up.
11th Nov 2020 10:13am |
I didn't mention them in my post because they are so rare and collectible (like the original pattern of 543384 or genuine 569203 rims)! Or genuine S1 split rims, for that matter. |
11th Nov 2020 10:46am |
Thanks, that's what I'm aiming to do - just these were cheap and local so thought they might be worth a punt! |
11th Nov 2020 10:57am |
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 |
No they aren't. Standard Defender rims are only 5.5" wide, suitable for sizes upto 7.50R16. 235/85R16 will require wider rims such as wolf rims or alloys. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
19th Nov 2020 5:55pm |
