Home > Maintenance & Modifications > Installing new rear quarter windows (Masai)
MarcusM
2007 Defender 90 Td5 HT Keswick Green
Hi All
This weekend I’m attempting to fit rear quarter windows to my 90 that I bought from Masai with the rubber trim.
I have the template to work off- but as I’m going to be irreversibly cutting in to the back panels are there any key tips from
Someone that has done the same job?
Can’t see much online video wise of it being done.
Thanks in advance!
M Keswick green 2007 Defender 90 TD5
Post #865802 6th Nov 2020 11:41pm
Dinnu
It is a very easy job to do.
Protect the area from scratching by painters tape.
A jigsaw with a metal blade did the job perfectly for me (I drilled 2 small holes next to each other to start, but one larger hole is also good). After cutting, I filed the edge to deburr but also to straighten the cuts. Advise to paint the edge to prevent corrosion.
The locking strip in the rubber profile should be installed on the inside for better visual appearance.
If the rubber profile is of correct length, then it is good. I installed 2nd hand glass, so purchased rubber profile by the meter. A very sharp knife can do clean cuts, and I cut a bit oversize and compressed the rubber as much as possible as rubber tends to shrink overtime. Also for the locking strip...if you stretch it, it will will go in easier, but then it will shrink over time, so try not to stretch it. Lube helps fitting, do not use dishwashing, it promotes corrosion. I used petroleum jelly, that is kind to the rubber. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #865816 7th Nov 2020 7:04am
MarcusM
Hi Dinnu
Appreciate your reply- really helpful to read before I get started.
Great tip about painting the inside to prevent corrosion.
Will post some photos as I get on for anyone else doing this for the first time Keswick green 2007 Defender 90 TD5
Post #865834 7th Nov 2020 9:43am
MarcusM
All went ok- thought the hardest bit was cutting - turned out fitting the glass in to the seal wasn’t as easy as I expected...
Great tips Dinnu- really helped plus having the locking strip facing inwards looks much better.
Seems like most people fit the locking strip facing outwards? (as is the case with the side windows installed before I bought the defender)
Post #865983 7th Nov 2020 11:01pm
Co1
Very smart. Nice looking 90. Thumbs Up
Post #866005 8th Nov 2020 9:01am
Dinnu
Looks great.
Re the locking strip orientation, it is like that sine the early 90s and 110s.
In the series the locking strip faces outwards.
One thing I forgot to advise you, the ends of the profile are on the center of the vertical sides, not at the bottom. And the ends of the locking strip would be on the other side (like a rotation of 180degrees) from the ends of the main profile. I will take picture of mine ti understand what I mean. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #866013 8th Nov 2020 9:58am
Dinnu
This is a left side factory installed quarter window. The ends of the rubber are on the outer side of the window.
Alpine windows have the locking strip on the outside. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #866032 8th Nov 2020 11:51am
MarcusM
Thanks for this Dinnu, in the end I did go for the strip connecting on this side. Finished the job today! Thanks for you help
Before
After
Post #866107 8th Nov 2020 6:01pm
CarMan
Bow down Rob
1993 200tdi 90 hard-top
1998 300tdi 90 soft-top
Post #866120 8th Nov 2020 6:37pm
Dinnu
Thumbs Up 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #866126 8th Nov 2020 7:07pm
notapnala
United Kingdom 2014 Defender 110 Puma 2.2 USW Keswick Green
not sure any of you guys are still on here.. i cant find a template to purchase anywhere, does anyone have a source of where i can get hold of the template for these quarter windows? thanks...
Post #1016157 23rd Nov 2023 1:58pm
notapnala
ha.. i just recognised the number plate on that familiar looking keswick td5. nice one doc !!
Post #1016182 23rd Nov 2023 5:19pm
Dinnu
Cannot help with a template, but maybe these help. The opening is slightly larger than the glass.
Sorry, just realized that left measurement was out of focus. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #1016188 23rd Nov 2023 6:42pm
