Home > Tdi > No Headlights.
Page 2 of 3 <123>
L110CDL
So just to update this a bit more . . . .
As i thought the lights were working okay, my mind was changed again as i was going home from work one day last week, it was dark and i was using the main beam and as i put dipped beam on, no lights, Censored i said, then i switched the the light switch off then on, got headlights again, big phew, so all the way home i never used the main beam again but as i was about 5 minutes away from home, the headlights went out Censored again i turned the headlight switch off then on and again the headlights came on and i made it back home. I have changed the unit for a new one now and will see how this goes.
Your prediction was right Bluericky Thumbs Up Clayton.
Keeper.
Post #871861 7th Dec 2020 9:03pm
jfh
South Africa 2007 Defender 110 300 Tdi SW Chawton White
I used old male and female plugs and made a loom, with a relay built in, to make it plug and play.
Now at about 5 or 6 years and no problems.
In the last 20 years I've lost 3 switches, so I got fed up and made it.
It's just one relay to remove the ampere load from the switch.
Post #872002 8th Dec 2020 6:34pm
L110CDL
Thanks jfh for the info, i will be trying to make up a relay loom and will be doing this hopefully sometime next year Thumbs Up
so on the way home last night and guess what, yes the lights went out Rolling Eyes so the next thing to change is the yellow relay under the fuses, i think it's something to do with the dim dip lights, the one in Millie is still the original one, so fingers crossed Confused Clayton.
Keeper.
Post #872208 9th Dec 2020 8:36pm
donmacn
If I were you Clayton, I'd just remove the dim dip completely. I've done that on mine a while ago.
If my memory's correct I think the most 'difficult' thing was making up a short jumper cable to cross two points on another of the relays.
At least it makes the wiring simpler and easier to fault trace. As I understand it it's also better for the headlight bulbs, that they're not burning at low voltage.
Certainly if you're going to consider replacing parts of that system anyway, then I'd thinking about ditching it. Donald
2000 Range Rover P38 4.0L V8
in the past..
1993 Discovery 300Tdi
Post #872251 10th Dec 2020 8:47am
All you need to do is unplug the dim dip resistor.
If you make up a loom (in the Boomslang style) you will have to disable the dim dip because otherwise you'll be trying to energise your relays on a reduced voltage.
Post #872278 10th Dec 2020 1:12pm
L110CDL
Many thanks Donald, food for thought there Thumbs Up Clayton.
Keeper.
Post #872498 11th Dec 2020 8:03pm
L110CDL
Is the dim dip resistor the yellow thing under the fuses Blackwolf ? if not, where is it please Smile Clayton.
Keeper.
Post #872499 11th Dec 2020 8:04pm
dorsetsmith
Post #872500 11th Dec 2020 8:08pm
L110CDL
Many thanks dorsetsmith Very Happy
Will have a look for it tomorrow Thumbs Up Clayton.
Keeper.
Post #872507 11th Dec 2020 8:24pm
L110CDL
So to bring this thread hopefully to a close and the final update Very Happy
As Millie went into my indie for some needed work on her, i asked my indy to have a look at my lights to see if he can find the fault, so i went back to pick Millie up, on the 3rd day and he had found the problem with the lights, there was not one fault but three Rolling Eyes
The first fault was the new light switch i had put in, it was not working at 100%. the second problem was the pink relay for the dim dip lights was not working, so he did away with the relay and added some wires
The third fault was the yellow relay under the fuses, he changed that one for one he new worked 100%
So my headlights work all ok and now i don't have dim dip anymore and my headlights, dipped beam and main beam are much brighter than before, well happy with the out come Very Happy Clayton.
Keeper.
Post #872961 14th Dec 2020 9:48pm
Sounds like a result, Clayton. Hopefully, that will be the last of your headlight woes. Darren
Post #872974 15th Dec 2020 6:15am
Procta
I will put money on the switch killing the two relays, I think you can get these relays off most MG Rover cars. I have a few spare relays off the rover metro, ( i took the fuse box system out of the car) So it might be worth you having a look at a few rovers ( if they are still in scrap yards now) just for handful of relays. Thumbs Up I cannot remember if it was the wiper one or the light one i tested from the metro, and it worked. Defender TD5 90 ---/--- Peugeot 306 HDI hatch back
Success is 90% Inspiration and 4 minutes Preparation # you can make it!
Post #873182 15th Dec 2020 10:57pm
L110CDL
Iv'e done away with one relay and have a plan sometime next year to help the head light switch out Wink Clayton.
Keeper.
Post #873354 16th Dec 2020 9:05pm
L110CDL
Hopefully it will be Darren Very Happy Clayton.
Keeper.
Post #873355 16th Dec 2020 9:06pm
dorsetsmith
add a relay to remove load from head light switch Idea
Post #873396 17th Dec 2020 7:46am
Page 2 of 3 <123>
