![]() | Home > General & Technical (L663) > Side “Box” |
Philm Member Since: 19 Jun 2020 Location: Manchester Posts: 176 ![]() ![]() |
Have a watch of this.
Why would you not wrap insitu?
Is it Groundhog day already. ![]() |
So he's done the ladder video and confirmed that the third rear hole required for the lunchbox is not there on the left side ~ impressive commitment, in that he even drilled an additional hole to see if the captive nut/threading was hidden behind. ![]() |
DSL Member Since: 20 Aug 2007 Location: Wandering the wasteland. Posts: 837 ![]() ![]() |
Was the captive nut there? Saves me watching it.
No captive nut
I was trying not to spoil the ending for those that wanted to watch it...
Bogblaster Member Since: 04 Jun 2007 Location: Glawstershire Posts: 119 ![]() ![]() ![]() |
6 bolts, 4 inside and 2 below the box covered by plastic caps. I’d say a 10 minute job. BB 2019 MY Disco 5 HSE Lux Audi A4 Avant 3.0L TDI Quattro - WOW 2016 90 Adventure |
shawnpalmer Member Since: 29 Sep 2020 Location: Cumming Posts: 28 ![]() ![]() ![]() |
There are 2 tamper proof tori bolts that secure the box on top to the roof rail, and then there are 2 bolts under the plastic caps underneath the box. Once you remove all the bolts the box easily comes off. It will leave you with 2 exposed mounting holes in the side railing below the window. It's not terrible looking uninstalled but there are holes left. I don't see it as a big deal, but it would be nice to figure out a way to cover the holes when not using the box.
I tried to order new side moulding, and it arrived in primer after paying over $200 for the part. It needed paint too, which makes the whole swap out a bit pricey. |
zilch Member Since: 11 Sep 2019 Location: Whitsundays & Sydney Posts: 823 ![]() ![]() |
A spare offside trim would do it I suspect, I had a new trim fitted after they changed
the ladder over to the near side, as the off side trim had two holes drilled for the ladder mounting screws where LR had originally installed it Cheers yet another pommie bar steward down under MY20 110 P400 SE Defender MY10 3.0 RR Sport |
That's the trim I ordered. It is costly to get it and paint it, but it clips on and off in a few seconds.
In my case the trim was costly for the dealer, who decided to move the ladder of their own accord
![]() MY20 110 P400 SE Defender MY10 3.0 RR Sport |
What's wrong with a pair of blind grommets? ![]() Click image to enlarge It still beggars belief that JLR did not adopt a system like the Givi monokey so that the box could be taken on and off with ease and even placed on the roofrack if required. ![]() Click image to enlarge There's got to be fabricator out there who could knock up a frame to pick up on all the mounting points? Last edited by Supacat on 14th Nov 2020 7:27am. Edited 3 times in total |
