Home > Puma (Tdci) > Overheating in 6th gear going uphill (SOLVED) |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17361 |
Have you tried replacing the cylinder head temperature sensor?
4th Nov 2020 6:49pm |
shropshiredefender Member Since: 05 Jun 2017 Location: Shropshire Posts: 834 |
As above - the CHT sensor will protect the engine from overheating by cutting the fuel supply momentarily giving the impression of a fuel problem and throwing no fault codes. Just because you're offended doesn't mean you're right.
4th Nov 2020 7:33pm |
Greyman110 Member Since: 29 Sep 2017 Location: London Posts: 327 |
I came across that today in a post somewhere.
I'll do that one and see. I thought I saw someone say you needed a special tool to remove it? I did clean it off today as it had a film of oil on it - If its the one that sits at the back of the engine bay by the injectors that is |
4th Nov 2020 7:45pm |
From the Workshop manual.
"Cylinder Head Temperature (CHT) Sensor The CHT sensor is located at the centre rear of the cylinder head (transmission end). The sensor measures the temperature of the cylinder head and not the temperature of the coolant." Just because you're offended doesn't mean you're right. |
4th Nov 2020 8:46pm |
Disco_Mikey Member Since: 16 Nov 2014 Location: Dundee Posts: 531 |
Replaced a few thermostats for sticking shut, causing it to overheat
Easy to test too |
4th Nov 2020 8:50pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8018 |
Does it need a special tool? Cheers
James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
4th Nov 2020 8:51pm |
bear100 Member Since: 22 Mar 2010 Location: South Wales Posts: 1913 |
No special tool, but what I did was cut a slot in the socket which made it so much easier
On mine the temp needle would rise slightly when cold 2016 Range Rover Autobiography 4.4 TDV8 2010 110 XS Utility 2.4TDCI 2010 Range Rover Sport TDV8 (gone) 2007 Discovery HSE TDV6 (gone) 1993 110 csw 200 tdi (gone) 1994 90 HT 300 tdi (gone) 1994 discovery 300tdi (gone) 90 hybrid 3.5 v8 (gone) Range rover bobtail 3.5 v8 (gone) |
4th Nov 2020 9:00pm |
Preston110 Member Since: 04 Nov 2020 Location: Sunderland Posts: 7 |
Exact same thing was happening to my defender 110. Was the coolant, crack somewhere in the system and it was leaking away and causing it to do the same thing.
4th Nov 2020 9:04pm |
How would you test to see if its working properly? |
4th Nov 2020 9:08pm |
I can't find any leaks in the system by looking but im not losing coolant unless I hit the 116 degree mark.
With the old coolant caps I could often hear them hissing after a run. |
4th Nov 2020 9:14pm |
Looking over the engine this morning, the radiator looks like it was replaced when the inter cooler was fitted by the previous owner.
When I unscrewed the coolant cap, the system is still pressurised from when I drove it yesterday. Is that a potential issue? |
5th Nov 2020 10:24am |
captain slow Member Since: 22 Jun 2011 Location: Herts Posts: 355 |
Have you checked your EGR valves? 2.2 Tdci 110 XS CSW Corris Grey
Prince Harry's D3 (gone but not forgotten) 300 Tdi 110 CSW (gone but not forgotten) |
5th Nov 2020 10:33am |
Egr was blanked off and removed when it went to have the maf and map done. It’s always been off but I had it done properly.
5th Nov 2020 10:58am |
Could this be the issue....
After driving the car and getting up to temp I felt the radiator. It’s hot to warm across the top and cold everywhere else. What do we think? |
5th Nov 2020 11:32am |
