![]() | Home > Technical > Central Locking Issues |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 ![]() ![]() ![]() |
I have to lock door 3 and 4 manually, rear and front 2 doors all good on remote ?
nick.bw Member Since: 26 Oct 2020 Location: Essex Posts: 76 ![]() ![]() ![]() |
Yep.
So manually, all doors lock, front back and rear. By the remote, all doors APART from the drivers door lock. Its a strange one! |
check wiring start with between door and a pillar in rubber swan neck
![]() Click image to enlarge Last edited by dorsetsmith on 5th Nov 2020 7:20am. Edited 2 times in total |
check the pink and orange wires which run in the convoluted rubber grommet/tube between the a-pillar and driver's door. 99% sure you will find one or both broken.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
Would it be the cables if I can lock all doors when I manually lock the forevers door, since it locks all the other doors?
Yes. A separate (and thinner) cable sends the lock signal to the 10AS unit when you manually lock the door. 02' 110 TD5 Double Cab Rebuild Thread
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17626 ![]() ![]() ![]() |
^^ This.
The driver's door when locked with the key is being locked by the key, not the central locking. |
I would look to the condition of the linkage between motor and lock in the drivers door. It's quite common for these things to get gummed up, which in turn creates resistance that the motor can't overcome to complete the travel necessary to work the lock. The fact that the other doors lock on the fob means that the drivers door motor is working to some extent as it operates a microswitch that sends the signal to lock the other doors, as it does when you lock with a key. Darren
spudfan Member Since: 10 Sep 2007 Location: Co Donegal Posts: 4748 ![]() ![]() |
One of the rear passenger doors on our 2008 Puma would not lock with the fob. It was a broken wire in the sleeve. I just joined it up with a small connector and it worked with the rest of the doors on the fob. 1982 88" 2.25 diesel
Ken B Member Since: 17 Dec 2013 Location: Essex Posts: 106 ![]() |
When I have door locking issues I have learnt it is most probably battery... check your charge. Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape. If it doesnt move and it should: WD-40. If it moves and shouldnt: duct tape it. |
