Home > Technical > Central Locking Issues
nick.bw
United Kingdom 2014 Defender 110 Puma 2.4 XS CSW Santorini Black
Hi all
When i put the key into the drivers door to lock the car, all doors lock
If i were to lock the car with the keyfob, all doors but the drivers door locks.
Is there anything you can think off which might have caused this?
Any place to look?
2014 puma 110
Its strange to see manually locking the car via the drivers door lock, it locks all the doors
Thanks
Nick
Post #865000 2nd Nov 2020 4:39pm
stew 46
England 2010 Defender 110 Puma 2.4 USW Bonatti Grey
I have to lock door 3 and 4 manually, rear and front 2 doors all good on remote ?
Post #865005 2nd Nov 2020 4:48pm
nick.bw
Yep.
So manually, all doors lock, front back and rear.
By the remote, all doors APART from the drivers door lock.
Its a strange one!
Post #865008 2nd Nov 2020 4:57pm
dorsetsmith
check wiring start with between door and a pillar in rubber swan neck
Post #865012 2nd Nov 2020 4:59pm
rallysteve
check the pink and orange wires which run in the convoluted rubber grommet/tube between the a-pillar and driver's door. 99% sure you will find one or both broken.
Post #865016 2nd Nov 2020 5:03pm
nick.bw
Would it be the cables if I can lock all doors when I manually lock the forevers door, since it locks all the other doors?
Post #865045 2nd Nov 2020 6:17pm
rallysteve
Yes. A separate (and thinner) cable sends the lock signal to the 10AS unit when you manually lock the door. 02' 110 TD5 Double Cab Rebuild Thread
Post #865046 2nd Nov 2020 6:23pm
^^ This.
The driver's door when locked with the key is being locked by the key, not the central locking.
Post #865048 2nd Nov 2020 6:24pm
I would look to the condition of the linkage between motor and lock in the drivers door. It's quite common for these things to get gummed up, which in turn creates resistance that the motor can't overcome to complete the travel necessary to work the lock. The fact that the other doors lock on the fob means that the drivers door motor is working to some extent as it operates a microswitch that sends the signal to lock the other doors, as it does when you lock with a key. Darren
Post #865081 2nd Nov 2020 8:49pm
spudfan
Ireland
One of the rear passenger doors on our 2008 Puma would not lock with the fob. It was a broken wire in the sleeve. I just joined it up with a small connector and it worked with the rest of the doors on the fob. 1982 88" 2.25 diesel
1992 110 200tdi csw -Zikali
2008 110 2.4 tdci csw-Zulu
2011 110 2.4 tdci csw-Masai
Post #865468 4th Nov 2020 11:18pm
Ken B
When I have door locking issues I have learnt it is most probably battery... check your charge. Defender 90 TD5 County -
You need only two tools in life: WD-40 and duct tape.
If it doesnt move and it should: WD-40.
If it moves and shouldnt: duct tape it.
Post #866150 8th Nov 2020 7:52pm
