Home > Maintenance & Modifications > Puma 2.2 Intake to airbox
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Lots of very helpful discussion around this one, so I though I would share this afternoons project.
After reading and learning about all what others have done, I bought the "kit" from local business 4x4manufaktur.ch
While at it I shortened the BAS turbo-to-intercooler hose by 20mm on Petes recommendation as it seemed a bit too close to the air box support I also added the LR bracket to hold the hose in place (LR057448)
Super happy with the result: here are some pics. (EDIT: not sure why I can't get photos in order)
Tomorrow I will modify the stock grill to cover it. Should look nice with the stainless piece ever so slightly visible.
Took a quick drive down to fetch some beer and immediately noticed a difference in sound and free breathing.
On a happy side note, I seem to have freed up quite a nice spot for a Provent (it never stops does it Rolling with laughter )
 Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #864065 28th Oct 2020 5:29pm
Dinnu
Nice work.
Question: how did you get the bottom part of the air box out. I know you need to pull up and then away from the wing, but I had the refrigerant pipe in the way, and did not want to let the gas out, or go to someone who can recover. Difference to my defender is I have the steering shaft on that side too. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #864102 28th Oct 2020 8:34pm
Angus_Beef
The best way I have found is this
After removing the top portion and air filter, remove the three bolts in the wheel well that hold the air box to the inner wing. Then move the air box horizontally to release the top two pins. Go under the car and you can reach up and separate the air box from the metal support. You can take the metal support from beneath.
Then go above and it becomes a game of Tetris. It’s easiest without the horrible standard intake pipe, but you can remove the box from above this way without even scratching the ac line. You will have to flex the ac line out of the way when you’re getting close. It should be noted that i was only able to position and remove the air box bottom after I had cut and removed the stock intake strangle-tube. Do this and everything else is easier.
Take your time. Don’t sweat it. Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #864107 28th Oct 2020 8:57pm
HardCharger
Just out of curiosity, why did you route the new hose upward rather than from below?
Does the company you ordered that from ship overseas? I was looking to re-do my Nugget intake to air box kit as the one who installed it for me did some things to the adapter box that I wasn't happy with (drilled a hole to route breathers into it then just sealed with copious amounts of sealant)
A friend of mine suggested that rather than go with a box adapter, a direct connection from intake to air box would be much more preferred so this kit you posted has my interest. If it's WAY cheaper than the Nugget solution, I may try this one next.
Thanks.
Post #864135 29th Oct 2020 1:57am
Angus_Beef
I went over the blower motor inlet because there is very little room under it. The space under it is the same size and shape as the standard intake tube. I had to unscrew from the wing and remove the blower intake in order to get the old tube out. Smashing the new hose flat and into the shape of the old one seemed a bit counter productive and there was ample room (and length) to go over it.
Post #864141 29th Oct 2020 6:43am
jimbo55
I did something very similar with my td5, 3D printed a bracket to go on the wing and 100mm hose to the airbox
Post #864147 29th Oct 2020 7:15am
Angus_Beef
This morning I tackled the grill. Simple matter of removing the inner "fins" that the standard grill has and drilling corresponding holes in the plastic. In the fender I installed M4 Blindnietmuttern and fastened it all together with stainless M4x20 Philips head machine screws.
Post #864237 29th Oct 2020 1:31pm
Very neat but I'd have to paint the stainless panel black, I'm afraid. Darren
Post #864239 29th Oct 2020 1:42pm
Angus_Beef
Sure, that would be easy enough. At the moment I kind of like the tease of something out of the ordinary.
But what is bothering me is the bright blue silicon adapter.... Ive already started looking online for a black one. Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #864242 29th Oct 2020 1:47pm
Dinnu
Thank you DeeEss for the tip. Not sure if it is easy to remove the metal support as we have the steering box in the way. But will give it a go in case I need to do it again. Reason I needed to remove the air filter was to remove the self tapping screw holding the small cover on top of the inner mudguard to remove the shock absorber/turret assembly. In the end I managed to get access to the screw buy shifting the airbox a bit. I also saw one suggestion on this forum to drill an access hole through the airbox.
As for black silicone reducer, there are plenty available, example :
https://www.aliexpress.com/item/3266392542...web201603_ 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #864311 29th Oct 2020 7:26pm
Angus_Beef
Hi, thanks for that. Yes there are a lot, and not expensive either. I found one from siliconeshop on eBay that should do the trick. Getting it from the Uk costs a few bucks more, but much faster than waiting on mail from China. Ill update once its received and in.
Cheers,
DS Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #864318 29th Oct 2020 7:46pm
HardCharger
Oh, OK. I reckon this explains the shape of the Nugget adapter box then. The information is still useful though.
Thanks! Thumbs Up
Post #864366 30th Oct 2020 6:16am
Roy5695
United Kingdom 2011 Defender 110 Puma 2.2 XS DCPU Indus Silver
I opted for a 102mm pipe from airbox to wing top. Covered by a snow cowl. Couldn’t get any more air in, much less restrictive and the same diameter as the airbox inlet.
Running double snow cowls also mean the front end is a bit more symmetrical for my
Own viewing pleasure πŸ˜‚ 2011 Defender DCPU 2.2 - https://www.defender2.net/forum/topic30623.html
Instagram - @r22oyp
Roy
Post #864542 31st Oct 2020 9:42am
jst
^^ Neat idea. How does sa compare pipe to cowl inlet slot? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #864684 31st Oct 2020 10:33pm
Angus_Beef
Roy
Nice solution! Not exactly applicable to my lhd truck per se, but very nice.
To threadjack my own thread, love your wheel/tire combo! 285 bfgs on 18s? Roaming around πŸ‡³πŸ‡΄πŸ‡¨πŸ‡­
Post #865072 2nd Nov 2020 8:11pm
