Home > INEOS Grenadier > automatic transmissions and transfer cases
NMBRPL8
Australia
if you have a 4wd an automatic transmission can you push start it?
i doubt a manual puma engined defender could be push started due to the fuel pressuring , but i ask all the same.
as a manual driver i have always found neutral a very useful gear to have when off roading, ie disengaging drive
Post #863578 26th Oct 2020 9:49am
Bluest
You can’t push start an automatic. Automatics still have neutral. 2007 110 TDCi Station Wagon XS
Post #863581 26th Oct 2020 10:04am
HardCharger
Pumas CAN be push started.
Automatics cannot, just pushed when in Neutral.
Though I remember from somewhere that if you can get an automatic up to about 60kph, you can try starting it then Mr. Green
Post #863742 27th Oct 2020 2:59am
It used to be possible to tow start some autos, back in the days when they were all-hydraulic in operation, but only if a rear pump was fitted to the transmission. IIRC the Borg-Warner 35 or 65 was sometimes so fitted.
These were popular on safari motors at one time since they could be tow started provided the TC was properly filled, but you couldn't push start them manually because of the speed necessary.
I don't think any of the modern electronic autos can be push or tow started.
Post #863758 27th Oct 2020 9:33am
discomog
Blackwolf you are definitely showing your age now. I remember working on the Borg Warner 35's as an apprentice. I don't know what was in that horrible red transmission oil but it sure cleaned your hands after a day stripping down the box. I'd love to have a drive in a car with the BW 35 box and compare it to my modern day 9 speed auto. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #863765 27th Oct 2020 10:41am
NMBRPL8
Australia
thanks everybody.
nice to know a puma can be push started. any tricks to that? if i park on a slope and run the battery down, could i roll start it? i thought the lack of electronics would intervene
Post #863769 27th Oct 2020 10:59am
I doubt that you could push/tow start a Puma with no electrical power whatsoever, but provided that the battery has some power, even if not enough to crank, it should work.
With no power at all there will be no way to excite the alternator so no power can be generated (so you couldn't tow start it with no battery fitted, for example). In theory you could probably tow start a 200tdi with no battery and get it running, although it might take a bit of fiddling around.
Post #863778 27th Oct 2020 11:39am
jst
not sure why i would use neutral if moving off road Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #863870 27th Oct 2020 6:29pm
ickle
IIRC even a 200tdi needs 12v to the fuel solenoid to start it?
Keith
Post #863885 27th Oct 2020 7:48pm
AndrewS
Or on road Shocked 130's have feeling's as well you know Smile
Post #863892 27th Oct 2020 8:07pm
PeeWee
England 2010 Defender 110 Puma 2.4 XS CSW Rimini Red
"Push starting" a Puma:
10/11 years ago I did an LR Experience in a 2.4 Puma and the instructor was quite clear that it could be bumpstarted on a steep hill. I say "bumpstarted" - brakes on, in gear, ignition on, take the brakes off and it would roll and start without the starter motor. I sem to recall that this was in low ratio as well.
Post #962352 20th Aug 2022 8:20pm
County V8
Wasn't that just to get it back down the hill if it stalled???
Post #962359 20th Aug 2022 10:35pm
PeeWee
Yes, it was But letting it start itself, without using the startermotor, isn't that different to bumpstarting ?
Post #962366 21st Aug 2022 7:11am
No, that is bump starting. It's also a useful technique in reverse on a failed, stalled, hill climb to get back down again. Darren
Post #962367 21st Aug 2022 7:29am
Dinnu
Keith
You are correct, from 12J engine onwards (change to timing belt driven injection pumps), they had an electrical fuel shut off valve on the injection pump. The valve is normally closed, so the engine will not start unless a 12V is supplied to the solenoid.
The 10J as fitted to series and some early coil sprung had a manual shut off. Those can be bump started without a battery. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #962368 21st Aug 2022 9:07am
