Home > Puma (Tdci) > Help some low life has tried to steal my 130!! |
a pic help us identity the plug for you
21st Oct 2020 6:53pm |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1082 |
Have you checked fuse 6 as per https://www.defender2.net/forum/topic35353.html ? Did they remove the BBUS? |
21st Oct 2020 7:11pm |
Tomotomo Member Since: 13 Feb 2018 Location: Bucks Posts: 71 |
Ok here's a pic of the plugs.
Is fuse 6 under the drivers seat? Thanks |
21st Oct 2020 7:28pm |
Click image to enlarge |
21st Oct 2020 7:29pm |
Andy RV Member Since: 26 Apr 2014 Location: Somewhere Posts: 66 |
They’re not from your sidelight and indicator are they? Have you checked behind the passenger side headlamp for more unconnected plugs? This is typically where the BBUS is located.
Shorting the indicator will blow the fuse powering the alarm which is why you’re not getting a flash on locking. |
21st Oct 2020 8:14pm |
Matt110 Member Since: 29 Jun 2014 Location: UK Posts: 685 |
Could I suggest that the priority should probably be moving the vehicle away from wherever it was, and or improving your security...
...they've clearly started one night and intend coming back to finish another. Just suggesting that might be a good plan over and above figuring out how to return it to how they've left it. (Not that fixing it isn't also a priority.... You get what I mean ) |
21st Oct 2020 8:17pm |
And the hole beneath your headlight is perfect for hiding an alarm switch for when they remove the headlight surround.
21st Oct 2020 8:20pm |
F6 15 amp Blue Alarm system BBUS
black plug right hand side with wire black with light green tracer and black ground wire pump rear screen bit hard see may be wrong can not work out wire colour for one you have fingers on a parts from black ground wire also if you have BBUS fitted mover it from this location Last edited by dorsetsmith on 21st Oct 2020 9:36pm. Edited 6 times in total |
And invite some friends over and get a shotgun... |
21st Oct 2020 8:22pm |
No these multiplugs are empty now. I have everything plugged back in side light indicator headlight and horn. All working Could they be for this bbus thing that is mentioned or are they different? |
21st Oct 2020 8:54pm |
Turns out it there was a blown hazard fuse which is why the indicators were not flashing with the fob.
Can some one confirm that if the missarm function works which it does door open and try and arm the horn sounds twice the alarm system is still intact and functioning? There were no blown fuses under the seat... |
21st Oct 2020 8:58pm |
This is a very cool idea play them at thir own game : |
21st Oct 2020 8:59pm |
Exactly my thoughts. Went out and turned the truck around so it's now right under my bedroom window. Blocked in by another vehicle with a camera pointing at and a hastily purchased steering lock fitted. Not going to bother with the shotgun but will be spending on beefing up my security players.... |
21st Oct 2020 9:05pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17473 |
No, those are Econoseal connectors and will not fit the BBUS. There are several connectors in that area which will be present but unused depending on the configuration of the vehicle, including the alarm sounder (used only if the BBUS is not fitted), the rear washer pump, and headlamp levelling motor. If everything that is there has a plug in it and some are left over, it is probably not an issue. The BBUS is a cube-shaped boxy thing and its connector has four black wires, all the same colour to make identification of each specific function difficult. |
21st Oct 2020 9:16pm |
