Home > Puma (Tdci) > Help some low life has tried to steal my 130!!
Page 2 of 2 <12
Tomotomo
Ok thanks for clarifying those connectors are not got BBUS.
Maybe mine never had one I will look more in the day light.
Thanks all
Post #862948 21st Oct 2020 9:22pm
Andy RV
If you set your alarm off do you get just the horns or a siren as well? My understanding of it is if you can hear a siren you’ve got a BBUS.
Post #862974 22nd Oct 2020 6:50am
I don't think that's right. I'm sure that the BBUS only sounds if the battery is disconnected (or flat).
The most definite way to check for the presence of a BBUS is to disconnect the battery without following the procedure to disarm the BBUS. Darren
Post #862979 22nd Oct 2020 7:24am
dorsetsmith
1. set your alarm off you get the horns a BBUS
2. BBUS sounds if the main starting battery is disconnected (or its voltage drops below set point ).
Post #862986 22nd Oct 2020 8:24am
Julie
Tomotomo wrote:
... but will be spending on beefing up my security players.... Shocked
Have you ever been thinking about a pedal lock
https://www.shirefabrications.com/safe-tpe...to-fit-rhd
In the evening I install it in my truck - and I'm quite sure I'm gonna hear them grinding this 4 mm steel plate down next to my bedroom Wink
Post #863337 24th Oct 2020 2:44pm
Sadly not if they tow it away first. Shocked
Post #863398 24th Oct 2020 9:02pm
Tomotomo
I think I am going to fit the optimill removable steering wheel and swivel lock looks to be one of the best prevention mods. I now dont think I ever had a bbus so I would like to install something that does the same job.
Post #863401 24th Oct 2020 9:09pm
Julie
Yes, if he manages to loosen my handbrake. It's 4 wheels locked Mr. Green
Post #863402 24th Oct 2020 9:32pm
You really don't want to know how easy that is to do. Shocked Big Cry
Post #863403 24th Oct 2020 9:36pm
Page 2 of 2 <12
