![]() | Home > General & Technical (L663) > Old vs New Defender 110 |
PCM Member Since: 25 Jan 2019 Location: North East Posts: 895 ![]() ![]() |
That video irritated me.
22900013A Member Since: 23 Dec 2010 Location: Oxfordshire Posts: 3150 ![]() ![]() ![]() |
No, by the time that one was built it was standard fit as part of the dsc. There is a dashboard button to turn it off, which presumably they did as not once can the TC be seen activating. The whole thing comes across as JLR paying for a promotional piece which is not a fair comparison. I'd have loved to have seen proper tests of approach and ramp angles, as we know who would win those... 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
MrEleven Member Since: 15 May 2020 Location: Glasgow Posts: 112 ![]() ![]() |
![]() Click image to enlarge ![]() |
snowplough on the front and a cherry-picker ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
Genuine question (not trying to be funny).
Is there a dashboard button to turn off the traction control on a 2014 Puma? I've never found one on mine, but I'm intrigued to know if it is actually there. Thanks folks. |
^ no
but a lot of guys here have wired a switch to the fuse for the ABS/TC, so they can switch it off when they want. personally, I don't see the fuss - learn how to drive with TC, and it will make you look great ![]() 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport V8 Supercharged ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Yes, says dsc and some lines like skid marks. Usually on the top row of the dash buttons. 2011 110 USW 1973 Series III 1-Ton 1972 Series III 1-Ton Cherrypicker 1969 IIA 1-Ton 1966 IIA 88" |
Thanks folks. I wondered what the button blank, top left, on my dash was!
What year and model is yours Joe? 2011 110 USW
milesr3 Member Since: 12 Feb 2013 Location: Suffolk Posts: 873 ![]() ![]() |
Don't the last of the Pumas have proper Dynamic Stability Control (DSC)? Our MY16 has the button to disable it and you get a warning light on the dash. |
2014 110 van (built January 2014). Hint. Hover over the little image of the vehicle by anyone's user name for details of their vehicle, if they've posted them. |
Zed Member Since: 07 Oct 2017 Location: In the woods Posts: 3355 ![]() ![]() ![]() |
Easy to add for 2.4 and Td5: https://pace4x4.com/shop/ols/products/defe...ctable-kit I haven't looked but someone must do a 2.2 version. WARNING. This post may contain sarcasm. |
Devon-Rover Member Since: 22 Jan 2015 Location: South Devon Posts: 925 ![]() ![]() ![]() |
From what I have seen MY14 as on a '14 plate will have ETC and ABS as standard, As that's why my "Poverty spec" USW has it. I know of a 2014 '63 'poverty' that didn't have it as standard and they were built 2 weeks apart
yet 2014 on a 64 plate will get ABS ETC and DSC as seen here https://used.landrover.co.uk/model-defender#/details/3059341 I don't have the DSC which is good as I didn't want it interfering when I know better in certain offroad conditions. The long and the short is If they showed a 14 plate truck It would of had ETC regardless. (EDIT) I have watched the video> Firstly whoever their "expert" is than he is useless. He should know that it does have it See the advert >> https://www.neneoverland.co.uk/listings/la...ion-wagon/ And he should know that in the type of situation he should of been fairy linear but firm with the throttle to get the system working and for it continue working and not back off the throttle just as it starts to get aggressive to deal with the wheelspin. All of them are 5 star plonkers Also can be found on Fb, Ytube, Insta & Twitter @4WDSouthwest |
At least he did (some) homework this time. Unlike some other reviews on YouTube, he knew how to use the TR programmes and that the suspension can be further raised when stuck.
I own both old and new. Totally different vehicles with different compromises in different legislative environments. I guess LR has invited these head to head comparisons by using the “Defender” name but it’d have probably happened anyway. In factory spec, the new Defender is clearly the better car to live with, the safer car to drive, the more capable in ‘weekend warrior’ off road settings. The old Defender can be modded and/or abused to perform better in extreme situations; will hold its cool and its value for longer; and can be made to perform utility roles than a unibody vehicle isn’t designed for. I love both. ![]() + New Defender 110 First Edition |
