![]() | Home > Technical > Front Caliper bolt socket |
It is just a normal, 12point/ bi-hex 14mm socket.
Steve 02' 110 TD5 Double Cab Rebuild Thread |
razz Member Since: 02 Oct 2015 Location: norfolk Posts: 403 ![]() ![]() |
Thanks Steve
Apologies, it is 13mm, just double checked as i was doubting myself. The swivel ball to axle bolts are 14mm bi-hex.
Sorry for the confusion! ![]() Steve 02' 110 TD5 Double Cab Rebuild Thread |
V8GPC Member Since: 18 Jul 2016 Location: Manchester Posts: 289 ![]() ![]() |
if they are rusted and to avoid rounding it is possible to tap a 1/2 inch 12 point or even a 12 mm (if badly rusted).
Worth while having these to hand too. |
