Home > Td5 > TD5 Foam air filters
bell-auto-services
New TD5 foam performance filters are here , only £34+£5 postage to the UK inc vat
http://www.bellautoservices.co.uk/index.php?page=itg_filters
Regards Pete
Post #5716 23rd Dec 2008 9:18pm
mrwoo
United Kingdom 2004 Defender 90 Td5 CSW Epsom Green
Hi Pete, is the airbox the same on the Puma as the TD5?
Thanks Rich Thumbs Up
Post #5730 24th Dec 2008 11:09am
bell-auto-services
The TD5 filter does fit inside the puma air box but the size is slightly different.
Regards Pete
Post #5731 24th Dec 2008 11:29am
jst
Pete, what are your thoughts on ITG filters in the PUMA? Cheers
James
110 2010 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #6918 5th Feb 2009 2:32pm
bell-auto-services
I cant comment on ITG as it would not be fare to name a brand spacificly.
What i will say is from my experience in some cases a foam filter can cause maf errors, i think and again im not 100%, its possibily because the airflow of the foam filter is to great and it takes the maf out of range.
Or its possibile the oil used on the filter contaminating the maf.
Which is why now i only fit standard paper filters to the puma.
Regards Pete
Post #6919 5th Feb 2009 3:11pm
jst
cheers Pete
interesting as the td5 Maf didnt have that problem did it Cheers
James
110 2010 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #6920 5th Feb 2009 3:13pm
bell-auto-services
Remember its a different maf running different tollerances on a totaly different engine management system,
but yes it is intresting that some cause problems even tho they are totaly different systems, you would have thaught they would be ok in 100% of cases.
Regards Pete
Post #6922 5th Feb 2009 3:16pm
