Home > Puma (Tdci) > Injector Removal
Moffett
Ireland 2008 Defender 110 Puma 2.4 XS CSW Stornoway Grey
Injector Removal
Hi folks, a former TD5 owner here, I have been driving a 2.4tdci for about three months now and so far I have been very much enjoying it. I have a few jobs to complete, one is leaking injector seals. As the injectors are leaking back I was planning on sending them off for recon whist I have them out. This will take a few days as they have to go in the post. My concern at this point is that I will loose prime. There doesn't seem to be a definitive way to bleed the fuel system on these. I am looking at that French kit which I assume has the correct connects etc. for easy install on the tdci fuel system. Has anyone used one? , they are about £130 delivered. Also, is there a cleaning kit that anyone recommends for the bores, I am worried about carbon etc. dropping into the injector port. I have a seat cutter to clean the carbon off the sealing face. The seal kit I bought came with new stretch bolts also. Any advice you would have would e greatly appreciated, thanks, Dave.
Post #860061 6th Oct 2020 1:13pm
You shouldn't need to prime unless you allow air to enter the system downstream of the combined LP/HP pump.
There are many cleaning kits available online, for example https://www.amazon.co.uk/gp/product/B0183S...&psc=1
These will have a bung to put in the hole to stop crud falling in the cylinder. A decent seat cutter will have a pilot which does the same job, but most reputable manufacturers such as SP recommend taking off the head. Of course nobody does that Inthe real world.
If you get the injectors serviced you will probably need to recalibrate them, which requires a diagnostic tool. If you don't get them refurbed make sure you know where each one came from or the same applies.
Post #860062 6th Oct 2020 1:44pm
hank
I did this job a couple of weeks ago. No need to reprime as you are disconnecting after the fuel pump. It will sort itself out on turnover when you're finished, just cranks for a few seconds before the injectors get fuel and starts.
Writeup here https://www.defender2.net/forum/topic53240-120.html > 110 XS Double Cab
Post #860064 6th Oct 2020 2:06pm
Naks
Handy tip from an indie workshop: add a bottle of 2-stroke oil to your tank and drive it for about a week, this will make the injector removal a lot easier Thumbs Up --
Post #860066 6th Oct 2020 2:11pm
Moffett
Thanks for your replies folks, I had planned to scribe them and return them in their correct order. Do I need the injector learn function even then Blackwolf? I have access to a Nanocom, but have only done a few jobs such as recover the EKA and train in a few keyfobs. I understood if I had my own set reconditioned and returned them in the correct order they would not need learning in? @Hank, I fill probably have the injectors disconnected for a week. MY fear is air will be seep into the system backwards through the pump I would probably be unlucky for the system to loose prime even at that time frame. I am off now to read through your write up. And thanks Naks, I will pop in some 2 stroke oil first thing tomorrow!
Post #860141 6th Oct 2020 8:56pm
Moffett
That write up is very helpful Hank, did you use the cutting head as a bung to block the injector hole when you were cleaning out the main bore?
Post #860145 6th Oct 2020 9:14pm
ozzie1989
Wales 2010 Defender 110 Puma 2.4 USW Bonatti Grey
When I did mine originally I didn't bother putting a bung in the hole as I didn't remove the rocker cover. The cheap set I bought seemed to catch most of the crud and then I used a hoover (small diameter pipe taped onto main pipe) to ensure it was all clean before putting everything back.
If you do struggle with air in the fuel line afterward, although you should be fine, it's quite easy to prime the system with a bulb or small hand pump.
After doing any work with the fuel system on these I'd always recommend doing a pilot learn etc. in the correct order to ensure the ECU knows where it's at with each injector.
In fact I often do it at service and it seems to magic away some of the diesel rattle that appears over time Thumbs Up Now: 2010 2.4 TDCi 110 Utility Wagon
Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition)
Post #860160 6th Oct 2020 10:50pm
Moffett wrote:
Thanks for your replies folks, I had planned to scribe them and return them in their correct order. Do I need the injector learn function even then Blackwolf? ...
Do be honest I don't know if getting the injectors refurbished will alter their individual characteristics to the extent that they'll need recalibrating or not, but I would think that it was highly likely that it will.
I have no doubt that the engine will run, but possibly not as well as it could. I would however always recommend that they are put back in their original positions.
Post #860216 7th Oct 2020 10:21am
hank
I can never get the injector learn to complete. Always get "Learning not completed status = 80" "...status = 88"
The cutting head picks up most of the crap, and the pilot stem theoretically prevents anything falling into the bores but I gave them a good blow out with compressed air and also a hoover for peace of mind.
Yeah I see what you're saying on air seeping back. Give it a go and see how you go I guess. Could get some threaded bungs to seal the system up in the meantime? I don't know the thread though. Might be worth contacting dorset smith for one of his hand primers... See here https://www.defender2.net/forum/topic70331.html or I've read about people charging the fuel tank with compressed air to bleed it, though I have no experience of that and don't know whether it can cause issues elsewhere? > 110 XS Double Cab
Post #860244 7th Oct 2020 11:46am
Moffett
I am thinking of just removing the injectors and replacing the seals at this point. The diesel leak I have is in line with what I have read on the forum. If it fails to work I will just have to do it again and send them off for refurb on the second occasion. It will be mid next week when I get at it. I will take pictures for posterity!
Post #860373 7th Oct 2020 9:38pm
hank
Definitely clean up the seats while you're there. I did mine too many times (twice by mechanics, twice myself) and could not get a seal until I cleaned the seats. The tool is cheap enough on amazon/ebay etc > 110 XS Double Cab
Post #860459 8th Oct 2020 1:55pm
ozzie1989
If you get injector learn issues make sure your clutch switch is working properly, the ambient temperature is in range and the fuel temperature is in range.
I once had the clutch switch bridged as it had started to fail and the learn wouldn't complete because one of its pre checks is that the clutch is released.
I find it easier to do both sequences in the summer, in the winter it can be very easy for the intake temp to drop below allowed levels quite quickly even after a run which can make it fail.
Edit: Forgot to say that a proper diagnostic tool from a garage or a Nanocom could not identify the failure when the clutch switch was bridged it just gave an error code and stopped. I plugged in the free ForScan and it told me straight away the clutch was depressed and it could not continue. I always use the ForScan now as it just gives much more plain English info. Now: 2010 2.4 TDCi 110 Utility Wagon
Post #860704 9th Oct 2020 7:55pm
Moffett
There is a status light to check the clutch switch output somewhere in the Nanocom. I saw it there though can't remember what menu. You wouldn't think it would effect the injector learn function however! Very useful information, I see some others were having trouble completing the sequence. Any of these things might have been the issue. I fit second row door hinges today. Still waiting on some bits. I am going to change the seals and not send them for recon and see if it cures the leak. I hate to go near it. The thing is running like a clock.
Post #861037 11th Oct 2020 8:40pm
Grenadier
When would you do this job? What signs do you see? Or is it based on KMs and ‘good practice’? Does the post-cleaned valves make the engine run noticeably better? If so, how? Smoother, quieter, cleaner, etc?
Just wondering.... Monsieur Le Grenadier
2011 Puma 110DC - Corris Grey
Post #869853 27th Nov 2020 8:40am
Moffett
I had a diesel leak onto my rocker cover that I couldn't trace. I brought it to a mechanic who suggested the injectors might be leaking back excessively. I opted to remove them myself to save money. Testing revealed the injectors were all within spec and not leaking. I think the issue was with the oilyseals on the rocker cover and nothing else! You might be able to replace these without removing the injectors, but I don't believe it would be easy to do. The injector seats were coked up with carbon and there was evidence of leakage on 2 and 4. I cleaned the seats and replaced the copper washers with quality items. I ran it for a week and changed the oil and so faryI am leak free! To be honest, there were no symptoms beyond the wet rocker cover. It was running and driving beautifully and thankfully it still is. My fears of loosing prime were unfounded, it did naturally take a few extra turns to start as the injectors had been out of the vehicle for one week. I was glad that I didn't have to complete pilot learn etc. as I have read it can be tricky to complete. But the Nanocom usually works, just a question of learning how to use it. I will cross that bridge when I get to it! I hope that answers your question. I would have left well enough alone but a visible leak like this would fail the roadworthiness test in Ireland.
Post #870033 27th Nov 2020 11:33pm
