Home > Technical > Windscreen removal - worth the risk ?
Page 2 of 3 <123>
What do you want doing? A replacement or swap etc?
In response to the fairy liquid comments above, you don't have to use anything, it can help, but just spraying water (like a mist) on the rubber won't do any harm... On tight screens I usually just spray some wd40 on a rag and wipe that around the inside of the rubber.
I have noticed that new Defender windscreens seem to be thinner than original, even my source for screens commented about them.
As for two people (or 3!) helping, make sure they ALL KNOW WHAT THEY ARE DOING!! One slap on the glass in the wrong place can very easily break it. I insist on NO help Laughing
Post #860207 7th Oct 2020 8:46am
Bluest
I need to replace the seal, It’s split and leaking. I have a new genuine LR one standing by, but I’ve been putting off for fear of breaking the glass. It’s a heated screen. 2007 110 TDCi Station Wagon XS
Post #860217 7th Oct 2020 9:27am
MaxRPM
Hi Greeni, I,m in Staffs and would appreciate you coming to fit a new screen in my T d5 90. New screen and seal are here.
ST19 9A N.
Thanks
Phil
Post #860219 7th Oct 2020 9:29am
Bluest, is there any stone chips on your screen anywhere at all? I'd be happy to do it for you if not!*edited from 'if so' Shocked .
MaxRPM, I need to look at my diary/weather, I can head your way, then ride the pumptrack at Cannock Very Happy
Post #860225 7th Oct 2020 9:52am
Bluest
There is a small chip, bottom middle, but not enough to worry the MOT man. 2007 110 TDCi Station Wagon XS
Post #860226 7th Oct 2020 9:59am
Right, the chances of it breaking from there is very likely due to the stresses on the glass when re-fitting, it'd be pointless to attempt it to be honest.
Post #860228 7th Oct 2020 10:01am
Bluest
No worries, I may as well have go myself and see what happens then. If it breaks, nothing lost, if it doesn’t, happy days. 2007 110 TDCi Station Wagon XS
Post #860239 7th Oct 2020 10:28am
Assume that it will break if it has a chip or crack, it is overwhelmingly likely to do so.
I think it is also highly unlikely that a professional would agree to attempt to refit a cracked or chipped screen for the same reason.
Post #860240 7th Oct 2020 10:31am
shanecl
Ireland 1989 Defender 90 V8 Petrol CSW Auto Firenze Red
Thanks for all the replies folks, Feck it, think i will tackle the job using the advice given. It would only niggle at me once everything goes back together.
1 out of 10 isnt too bad of odds
Post #860252 7th Oct 2020 11:05am
I did a video how-to last year and never uploaded it anywhere becasue it wasn't the best video..fitting a screen entirely one handed made it a bit wobbly to watch Laughing ... I have just took some screen shots for tips..
I use silicone gun nozzles x 2 back to back and cut down to feed the string easily into the rubber...
May give you an idea..
Post #860258 7th Oct 2020 11:42am
shanecl
thats a great idea Greeni with the silicone nozzle
Post #860446 8th Oct 2020 11:26am
Angus_Beef
Norway 2015 Defender 110 Puma 2.2 SW Corris Grey
Here's what happened to mine just a few weeks ago. Defender specialist who has done hundreds of them. There was a tiny stone chip I didnt even know was there. FYI the replacement heated windscreen (covered by insurance) was 1178.00 CHF
Shocked
 Roaming around 🇳🇴🇨🇭
Post #860456 8th Oct 2020 12:45pm
Yeah you probably wouldn't have noticed it, being in front of the obscuration band, and probvably hidden underneath the wiper too!
Post #860463 8th Oct 2020 1:34pm
Angus_Beef
Yepp. The good news is that JLR covered corrosion repair and paint for the windscreen frame and the windcreen blocks!
 Roaming around 🇳🇴🇨🇭
Post #860467 8th Oct 2020 2:13pm
shanecl
[quote="DeeEss"]Here's what happened to mine just a few weeks ago. Defender specialist who has done hundreds of them. There was a tiny stone chip I didnt even know was there. FYI the replacement heated windscreen (covered by insurance) was 1178.00 CHF
Shocked
Shocked Shocked just checked and a heated genuine screen is £380 pounds, hmm gonna double check how bad this seal looks Laughing Laughing Laughing
Post #860623 9th Oct 2020 11:15am
Page 2 of 3 <123>
