![]() | Home > Technical > Windscreen removal - worth the risk ? |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4228 ![]() ![]() ![]() |
I need to replace the seal, It’s split and leaking. I have a new genuine LR one standing by, but I’ve been putting off for fear of breaking the glass. It’s a heated screen. 2007 110 TDCi Station Wagon XS
MaxRPM Member Since: 15 Jan 2013 Location: South Staffs Posts: 1114 ![]() ![]() |
Hi Greeni, I,m in Staffs and would appreciate you coming to fit a new screen in my T d5 90. New screen and seal are here.
ST19 9A N. Thanks Phil |
Bluest, is there any stone chips on your screen anywhere at all? I'd be happy to do it for you if not!*edited from 'if so'
![]() MaxRPM, I need to look at my diary/weather, I can head your way, then ride the pumptrack at Cannock ![]() Last edited by GREENI on 7th Oct 2020 9:59am. Edited 1 time in total |
There is a small chip, bottom middle, but not enough to worry the MOT man. 2007 110 TDCi Station Wagon XS
Right, the chances of it breaking from there is very likely due to the stresses on the glass when re-fitting, it'd be pointless to attempt it to be honest.
No worries, I may as well have go myself and see what happens then. If it breaks, nothing lost, if it doesn’t, happy days. 2007 110 TDCi Station Wagon XS
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17573 ![]() ![]() ![]() |
Assume that it will break if it has a chip or crack, it is overwhelmingly likely to do so.
I think it is also highly unlikely that a professional would agree to attempt to refit a cracked or chipped screen for the same reason. |
shanecl Member Since: 20 Mar 2013 Location: Louth Posts: 514 ![]() ![]() ![]() |
Thanks for all the replies folks, Feck it, think i will tackle the job using the advice given. It would only niggle at me once everything goes back together.
1 out of 10 isnt too bad of odds |
I did a video how-to last year and never uploaded it anywhere becasue it wasn't the best video..fitting a screen entirely one handed made it a bit wobbly to watch
![]() I use silicone gun nozzles x 2 back to back and cut down to feed the string easily into the rubber... May give you an idea.. ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
thats a great idea Greeni with the silicone nozzle
Angus_Beef Member Since: 30 Apr 2015 Location: Oslo Posts: 434 ![]() ![]() ![]() |
Here's what happened to mine just a few weeks ago. Defender specialist who has done hundreds of them. There was a tiny stone chip I didnt even know was there. FYI the replacement heated windscreen (covered by insurance) was 1178.00 CHF
![]() ![]() Click image to enlarge ![]() Click image to enlarge Roaming around 🇳🇴🇨🇭 |
Yeah you probably wouldn't have noticed it, being in front of the obscuration band, and probvably hidden underneath the wiper too!
Yepp. The good news is that JLR covered corrosion repair and paint for the windscreen frame and the windcreen blocks!
[quote="DeeEss"]Here's what happened to mine just a few weeks ago. Defender specialist who has done hundreds of them. There was a tiny stone chip I didnt even know was there. FYI the replacement heated windscreen (covered by insurance) was 1178.00 CHF
