Home > Puma (Tdci) > Puma 2.2 oil service message. 3 reasons it will come on.
Page 2 of 2 <12
macfrank
Changed the engine oil today and remembered to try that second method to reset the oil service message. Smile It didn't work Sad But something else showed up that I can't make head nor tail of:
Question
It is displayed when you switch OFF ignition again with the reset button still pressed.
I tried several combinations of ignition on/off and button presses but nothing else came up.
Post #968653 22nd Oct 2022 4:10pm
Ianh
I’m assuming you get the normal mileage and trip mileage displaying when you turn the ignition key , just when you turn off the ignition while holding the trip reset you get the screen you show in the picture and wondering what it is.
I too am intrigued on what it’s showing
Plus a shame the Nanocom support process did not work, which seems to have been the case when someone else tried it and reported it did not work on the Nanocom forum. Perhaps it’s something that works on transits but not defenders.
Post #968655 22nd Oct 2022 5:04pm
macfrank
Yes, what I did was: button press -> milage+trip, ignition on -> display goes blank, ignition off -> "R ..." shows until button is released. I didn't try to press the button after ignition on.
To my "software brain" this looks like a software version number, i.e. 7.4.0, the "R" for "release", but that's just a wild guess.
Post #968660 22nd Oct 2022 6:32pm
Balvaig
Scotland 2016 Defender 90 Puma 2.2 Landmark LE Corris Grey
7th April 2000 ?
Post #968674 22nd Oct 2022 8:30pm
macfrank
Unlikely. It's a MY 2015, produced September 2014.
It's also not the EKA Rolling with laughter
Post #968676 22nd Oct 2022 8:39pm
Ianh
Just been on the Nanocom site and there is a beta 1.37 now available.
Among the updates is a reset for the oil service message.
Note there seems to be some other interesting updates for the 2.2 as well
Changes incorporated in this release:
Vehicle specific:
- Defender PUMA 2.2 Service Resets introduced containing: Oil Service, Turbo Replacement, Mass Air Flow sensor, High pressure fuel pump replacement, EGR throttle replacement, EGR valve replacement, DPF and DPF pressure sensor, Engine Adaptive values.
- Defender PUMA 2.4 added Status report for Pilot Correction procedure.
Bugs & fixes:
Defender Puma 2.4 Pilot Correction Engine temp bug fix
VIN TOOL will now be able to instruct key ECU`s to do a self VIN learn to avoid Not all VIN match detection error.
Post #985703 16th Mar 2023 2:04am
Ianh
It’s been 12 months but less than 5k miles since I last replaced the engine oil, hence the oil service message has popped up on the dash.
So I have just replaced the engine oil and filter but this time decided to see how the new Nanocom facility to clear the message would work.
I can report that it works perfectly and the oil service message can be cleared with the Nanocom now.
You need software version v1.37 or higher to do it, noting latest full software release is V1.38 ( I have this version loaded).
It’s all pretty simple, just connect Nanocom to OBD2 port, turn ignition key to II but don’t start engine.
Then on Nanocom menu select, Defender, Puma, Service reset, oil reset.
Power down Nanocom, remove ignition key, disconnect Nanocom from OBD2 port, insert key and turn to position II and the oil service message is gone Very Happy .
Post #1039285 6th Jul 2024 1:50pm
Page 2 of 2 <12
