Home > Technical > Adding additional alarm plunger switches to TDCI
Andy RV
Hello,
I’d like to add a couple of additional ‘bonnet’ alarm switches to my Puma to trigger the alarm if the headlight surrounds are removed. My plan is to make a loom up to fit between the male & female plugs for the standard bonnet alarm then add additional switches from there.
Will this work? Are the switches normally open or normally closed?
Thanks
Andy
Post #859778 4th Oct 2020 4:09pm
Andy RV
Just tested the bonnet switch, it’s normally open... so wiring this up in series should work?
Post #859782 4th Oct 2020 4:35pm
BuckBlu110
United Kingdom 1994 Defender 110 BMW M57 3.0 Diesel CSW Buckingham Blue
Can’t see why not, not a bad idea thinking about it.
Post #859784 4th Oct 2020 4:54pm
Martin
Site Admin
They need to be in parallel. In series they would all need to be triggered to close the circuit.  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #859788 4th Oct 2020 5:03pm
Dinnu
Not sure if I understand this right, but Andy RV tested the switch and stated it is NO. That means, when the bonnet is in its closed position, the circuit is closed (which is how it should be for an alarm system). If circuit must be closed to to be ok, then all switches have to be in series so if anyone is open, the whole circuit is open. Or I am missing something? 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #859789 4th Oct 2020 5:14pm
Andy RV
Dinnu, that’s my non-electrician understanding of it! When the bonnet is closed it compresses the switch providing continuity for the circuit. A break in the continuity is what triggers the alarm.
I’ve ordered the parts so I’ll see how I get on. I’ll need to make some brackets up to secure the switches.
Post #859793 4th Oct 2020 5:34pm
macfrank
For all the doors it's closed door = open circuit. The switches connect to ground, when open.
Is it really different for the bonnet?
Or just buy this one
https://www.landroverdefendersecurity.com/...r-defender
Cool
Post #859808 4th Oct 2020 6:15pm
Andy RV
Just had my switches delivered, they’re normally closed, not open! Not sure how I managed that when I tested the one in-situ in the engine bay... Parallel circuit it is!
Post #860123 6th Oct 2020 6:02pm
discomog
If you ordered a genuine LR switch you will not have to manufacture a bracket as there is an existing mounting hole on the opposite side of the bulkhead, the pin switch just clips in. Defender 90XS SW
Mini Countryman Cooper S
Morgan Plus 8
Post #860126 6th Oct 2020 6:25pm
macfrank
Thumbs Up So, same as for doors.
It IS confusing, though, when you open the normally closed bonnet, you close a normally closed switch by not pressing it to trigger the alarm... Shocked Laughing
Post #860132 6th Oct 2020 7:09pm
Andy RV
I’ve made the loom up and and it works perfectly, just need to sort the brackets out and it will be ready.
I presume the perfectly sized apertures beneath the headlights were originally designed for small headlight wipers?
Post #860823 10th Oct 2020 11:29am
Nobody knows what those holes are for, the Defender headlight washers don't fit them. I suspect they were for something that never materialised.
Post #860829 10th Oct 2020 12:32pm
