Home > Puma (Tdci) > MOT emissions failure
Page 2 of 2 <12
Julie
If the system is too dirty, things will get even worse if you heat up the system on the motorway.
Clean your EGR. You should do it by hand - because chemical products (which are also available) loosen the sooth at once. Injectors may end badly if they get too dirty
https://www.drivingline.com/articles/egr-diesels-necessary-evil/
The sensors also cause problems but imo you should watch out for sooth in the EGR
Post #859045 30th Sep 2020 10:10pm
KMBXXX wrote:
... What you say about hot engines does remind me of another issue. She runs like a dream with 91k on the clock but was a little bit wobbly (a couple of minor stutters at low speed) on two days when the temperature was in the 90's. I thought that strange because, as you rightly say, diesels run better when hot.
Any compression-ignition engine will run best when the engine itself is hot (which helps efficient and full combustion) but when the induction air temperature is as low as possible, which increases air density and hence the amount of oxygen drawn (naturally-aspirated) or blown (charge induction) into the combustion chamber on the induction stroke. This is of course the reason why intercoolers are provided.
So ideally you want a hot engine on a cold day.
Post #859070 1st Oct 2020 8:14am
Dinnu
Adding to blackwolf, find a test station deep in a valley, ideally below sea level. Although the MAP sensor might adjust for that.. sigh..... technology. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #859072 1st Oct 2020 8:23am
Page 2 of 2 <12
