- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Home > Off Topic > Central Heating Wireless Stat Installation help wanted. |
Ianh
Thanks pat.
So my last post is the route to take if leaving your existing programmer in place and connecting your stat receiver . Once done you just put the programmer in permanent central heating on mode. Controlling heating times etc from the stat in the house.
However you would like to remove the old programmer as well and fortunately your model stat can control heating and hot water so in effect is a programmer. So we can use that.
I will work out how after looking at circuit diagrams again. However will take a few days as I’m a bit tied up.
Let’s take this to a PM as I don’t expect many others are that interested in the specifics of this boiler and stat wiring combination
4th Oct 2020 6:00pm |
