Home > Maintenance & Modifications > Drawer/Storage in a Td5
Page 2 of 2 <12
rallysteve
Intercept wrote:
Mine came with a Nene Overland branded drawer but presumably they just badged someone else's product. Regardless of Nene's reputation, the drawer is very solid and works just fine even when there is 440Kg of water in butts on top.
That looks identical to my MSS one so suspect Nene just rebranded theirs. 02' 110 TD5 Double Cab Rebuild Thread
Post #857872 24th Sep 2020 2:34pm
BaronDefenders
United Kingdom 2004 Defender 90 Td5 CSW Santorini Black
LRA, yes it does have the tiedown points in the tub. That's good thinking. Thanks for the idea! Very Happy Charlie
1949 Series 1 80 (SOLD)
2002 Td5 90 (SOLD)
2008 Freelander 2 (SOLD)
1958 Series 2 88 Pastel Green (2019 LR Legends Best Restored)
1983 V8 110 Limestone (Previously owned by Tom Sheppard MBE)
2004 Td5 90 Santorini Black (Td5INSIDE Powered & Rebuilt by CSK)
2012 Puma 110 Zermatt Silver (Overlanding Build)
Instagram: @BaronDefenders
Post #857873 24th Sep 2020 2:39pm
Intercept
United Kingdom 2002 Defender 110 Td5 Black LE Java Black
Thanks Steve - having looked at their website it is the same as https://www.mobilestoragesystems.net/produ...6422410119 except for the lack of the 5-bar treadplate facing and top plate (my top is stainless steel with a diamond ribbed polymer board inset).
Post #857878 24th Sep 2020 3:19pm
rallysteve
That is interesting and beneficial for you i suspect. My only issue with ours is that the 2mm chequerplate top is unsupported in the centre and is far to weak for heavy loads. I have to put a bit of plywood on it for moving anything heavy (e.g. Transfer Box). When i rebuild I am going to add some central support and use a piece of 3mm chequerplate to strengthen it. Thumbs Up
Cheers,
Post #857881 24th Sep 2020 3:28pm
Page 2 of 2 <12
