![]() | Home > Maintenance & Modifications > Drawer/Storage in a Td5 |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 ![]() ![]() ![]() |
That looks identical to my MSS one so suspect Nene just rebranded theirs. 02' 110 TD5 Double Cab Rebuild Thread |
Intercept Member Since: 27 Feb 2017 Location: Suffolk Posts: 587 ![]() ![]() ![]() |
Thanks Steve - having looked at their website it is the same as https://www.mobilestoragesystems.net/produ...6422410119 except for the lack of the 5-bar treadplate facing and top plate (my top is stainless steel with a diamond ribbed polymer board inset). |
That is interesting and beneficial for you i suspect. My only issue with ours is that the 2mm chequerplate top is unsupported in the centre and is far to weak for heavy loads. I have to put a bit of plywood on it for moving anything heavy (e.g. Transfer Box). When i rebuild I am going to add some central support and use a piece of 3mm chequerplate to strengthen it.
![]() Cheers, Steve 02' 110 TD5 Double Cab Rebuild Thread |
