Home > Technical > Bit dry perhaps?
bodstruck
Bit dry perhaps?
FFS! Not sure if this car has had any maintenance in the last year or so. Offside rear wheel. Just need to assess what else got knackered in the process. Sad
Post #857462 22nd Sep 2020 4:29pm
jst
Wow, not seen one that bad for a while. Did owner not hear, feel it? See it glowing? Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #857490 22nd Sep 2020 7:21pm
bodstruck
Clearly not. All the grease had been flung out and it was so dry it must have been going for some while.
I didn't notice it on the drive back from Canterbury. Heard it on a short trip yesterday evening, stopped the truck and could smell it. Gave the wheel a tug and the amount of play left me wondering if would get home.
Bearing, brake pads and a disk required at least. Hoping there is no damage to the axle.
Will check the others before heading off again.
Post #857495 22nd Sep 2020 7:38pm
grafty99
Oh dear Shocked
It may have damaged the stub axle, looking at that Confused 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #857503 22nd Sep 2020 8:15pm
bodstruck
That is my worry. It does not seem bad on first inspection but I do need to work out how to get the bearing inner race off sonja can inspect fully.
Post #857506 22nd Sep 2020 8:35pm
grafty99
My area of concern would be the running surface for the hub seal. If that's damaged then the grease is going leak out/water get in and you'll be back to square one Exclamation 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #857507 22nd Sep 2020 8:42pm
bodstruck
The hub is definitely kaput. Come to think of it, I dont even recall seeing the remnants of a seal when I took it off. Hmmm.
Grease all over the disk and pads so the shopping list is
Bearing
Hub
Brake pads
Possible stub axle
New drive flange (worn so may as well replace now).
Post #857513 22nd Sep 2020 9:00pm
grafty99
It might be worth getting a stub axle anyway, you know it'll be right then - definitely strip and check the other side, you might need 2 sets of bearings and seals Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #857514 22nd Sep 2020 9:06pm
ickle
Is there an inboard oil seal on the driveshaft? If so need that as well.
Post #857599 23rd Sep 2020 11:29am
bodstruck
It looks like they took one kit and shared it across two sides Very Happy
No sign of oil seals, no lock washers. They have either disintegrated or were never there.
At least we can do it properly this time round Thumbs Up
Thanks for the tips, I'll make sure I get all those bits.
Post #857611 23rd Sep 2020 12:07pm
bodstruck
There do appear to be different options for hubs and stub axles. Assuming it has the correct axle, does anyone know what part numbers I should use for a 2005 110 td5?
Post #857612 23rd Sep 2020 12:10pm
bodstruck
Parts ordered. Was hoping to tackle this weekend but they are not likely to be here until Mon/Tue.
Stub axle, hub, bearing kit and new HD drive flanges. Going to convert to the older style two nut and locking washer for the bearing while I am at it.
Going to check the other side over the weekend as well, just to be sure.
Post #858039 25th Sep 2020 7:40am
