Home > Maintenance & Modifications > Leisure Battery fitted to SSE Utility
Liam Murphy
United Kingdom 2009 Defender 110 2.5 TD HT Tamar Blue
I've recently bought a 2009 ex SSE 110 Puma, and I'm trying to find information on refitting the leisure battery.
The battery itself has been removed, but there still seems to be a fuse box remaining, where the battery terminals are connected:
Can anyone assist me in identifying any additional parts?
Under the Driver's seat, there is the usual fuses which I've checked in the Haynes manual:
Nothing looks out of the ordinary but the wabco is the ABS correct?
I'm thinking of adding the same brand 95AH Yuasa battery, with a 110 amp wire relay kit:
https://www.ebay.co.uk/itm/1M-Split-Charge...2763.l2649
Any help or assistance will be greatly appreciated Smile
Cheers!
Post #857244 21st Sep 2020 5:11pm
Joe the Plumber
2014 Defender 110 Puma 2.2 HT Fuji White
If it's any help, Halford's leisure batteries are made by Yuasa, and it's normally pretty easy to get a trade card there which will get you 20% off.
I bought four of their HLB700 100AH batteries a few weeks back (it's a Yuasa L36-EFB with a different label) and got £88 off the RRP.
You do have to be careful with leisure batteries as many of them are, er, cra, er, not very good. If you've got time, there's loads of info here:
http://www.aandncaravanservices.co.uk/battery-technology.php
Post #857258 21st Sep 2020 6:35pm
Liam Murphy
Thanks! Yeah i've read somewhere that you can run AGM leisure batteries below 50%, so I was thinking of the AGM version of that range. They're a little more at £160 though:
https://www.tayna.co.uk/car-batteries/yuas...gJ8dfD_BwE
Post #857265 21st Sep 2020 7:04pm
dorsetsmith
wabco is the ABS correct yes
second pic down is voltage sensing split charging unit ( no long made )
Post #857269 21st Sep 2020 7:18pm
Liam Murphy
So that's the split charging unit? I'll put a battery on it and see if it's still working before I order a new one
Post #857271 21st Sep 2020 7:22pm
jst
Just put a volt meter on its outputs and check engine running.
Numax leisure batteries I have found to be 8n readily good value and performance, have run them for over 10 years now. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #857297 21st Sep 2020 8:03pm
Joe the Plumber
Have a read up on AGMs in the link I posted (there's various other articles at the top of that site). I don't think you'll buy one afterwards.
Post #857302 21st Sep 2020 8:08pm
Liam Murphy
I didn't buy one after reading that!
Thanks, went for EFB instead
https://www.amazon.co.uk/gp/product/B07F8V...&psc=1
Post #857340 21st Sep 2020 11:09pm
MichaelE
I gave up on that site after trawling round for 15 minutes trying to find out what AGM stands for. Not even in the AGM batteries section or FAQs does it say. Nowhere.
Post #857347 22nd Sep 2020 3:33am
Joe the Plumber
Absorbed Glass Matting. I'd give it another go if I were you. There's stacks of very sensible information on there.
The L36-EFB Yuasas are the Halfords HLB700 ones I got (same battery, different label).
If you can't get a trade card, they're currently £110, otherwise £88. Sorry Liam.
Post #857354 22nd Sep 2020 5:24am
Liam Murphy
Yeah I couldn't get a trade card in time, so went with the Amazon link instead. Thanks for the heads up though!
Have you daisy chained 4 of them together?
Post #857367 22nd Sep 2020 7:26am
jst
whats the capacity of that battery then? i see its 100Ah but what the storage size? Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #857385 22nd Sep 2020 9:58am
s55shh
my 2011 ex SSE Utility had two leisure batteries under the bulkhead behind the seats. Under the drivers side one was the eberspacher. There was no room under the seat as it had all of the isolator wiring for the winch.
Post #857391 22nd Sep 2020 10:42am
Joe the Plumber
That's a shame, but I know when you need something now, you need it now.
Yes, they're in parallel, so 400Ah capacity but still 12v (you link all the positives one side and the negatives the other.)
I perhaps should have mentioned they're on our narrow boat, not in my Defender though!
Post #857415 22nd Sep 2020 12:54pm
Liam Murphy
It's reading about .5 / .6V when the engine is running, is that enough for a split charge?
Post #857417 22nd Sep 2020 12:59pm
