Home > Maintenance & Modifications > Leisure Battery fitted to SSE Utility |
Liam Murphy Member Since: 29 Jul 2020 Location: South Wales Posts: 95 |
Thanks for all the info and the manufacturer, much appreciated.
Is this the main fuse you referenced? Click image to enlarge There's a definite break in volts in between these two points. One side is reading over 12v whilst the other side of it is reading 0.6v so I suspect this is the issue. If I can't find a replacement I'll try contacting the manufacturer |
22nd Sep 2020 5:00pm |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4227 |
That fuse looks like one of these https://www.arc-components.com/0-378-33-vi...-1849.html 2007 110 TDCi Station Wagon XS
22nd Sep 2020 5:12pm |
That's exactly what it looks like! Thanks!
I've just taken the 200 fuse off and the voltmeter is reading a flat 0, which suggests it's all good inside, right? I'll get a spare on order anyway |
22nd Sep 2020 5:28pm |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8145 |
Join the wires on one of the studs, what do you get from outputnofnspkit charge then. It probably needs the main battery over a set voltage 13.6? Before it will switch over anyway. Cheers
22nd Sep 2020 6:04pm |
MichaelE Member Since: 18 Jan 2020 Location: Crawley West Sussex Posts: 155 |
Thank you |
23rd Sep 2020 4:24am |
