Home > Puma (Tdci) > Rear shocks |
I've recently fitted new OE shocks to mine after about 50k miles on the originals and I'm very pleased with the result. Darren
17th Sep 2020 8:45pm |
stew 46 Member Since: 26 Jan 2012 Location: Wadebridge ,cornwall . Posts: 561 |
Are they softer ??
Stew |
17th Sep 2020 9:26pm |
Not particularly - they just offer more control than the worn ones that they replaced. I have, however, also fitted station wagon rear springs to my USW which are softer, initially at least, which makes for a more pleasant ride when empty. Darren
17th Sep 2020 9:42pm |
I like the idea of that
17th Sep 2020 9:45pm |
After driving a couple D3’s and nice tdv8 over the last 10 years my defender feels like I’m in a metal box
17th Sep 2020 9:47pm |
ozzie1989 Member Since: 25 Feb 2009 Location: Wales Posts: 282 |
I also run the station wagon springs (triple rate) along with Koni Heavy Track shocks. In my opinion the comfiest you can make a Defender 110 on the rear (if you're looking for something softer).
They are fully adjustable should your circumstances change. Now: 2010 2.4 TDCi 110 Utility Wagon Then: 2004 2.5 TD5 90 Hard Top (X-Tech Edition) |
17th Sep 2020 9:50pm |
MK Member Since: 28 Aug 2008 Location: Santiago Posts: 2442 |
Or std only oil filled shocks. Gas charged shocks will be harsher all the time. Puma 110" SW
18th Sep 2020 1:51am |
Bluest Member Since: 23 Apr 2016 Location: Lancashire Posts: 4227 |
Why will gas charged shocks be harsher, it has no bearing on the damping force?
I went OME shocks (don’t have the model number to hand) which definitely took the harsh edge off speed bumps and pit holes. 2007 110 TDCi Station Wagon XS |
18th Sep 2020 7:11am |
diduan Member Since: 13 Oct 2016 Location: Central Balkan Posts: 260 |
+1 for OME Defender 110 SW MY2011 2.4tdci decat, no EGR
Jeep Wrangler YJ 1990 4.0. Front 78' Dana 60, Rear CUCV 14 bolt |
18th Sep 2020 7:40am |
