![]() | Home > Puma (Tdci) > Think oilpump broken.. again... |
ickle Member Since: 22 Jul 2010 Location: South Vendee Posts: 1849 ![]() ![]() ![]() |
![]() Good luck! |
dazzling1611 Member Since: 08 Jun 2020 Location: morpeth Posts: 35 ![]() ![]() ![]() |
ive read somewhere that they changed the oil pump from 2011 and its prone to failing as the pump vains are some kind of plastic. The info ive found out is the earlier ones are much more reliable and fit the later engines.
Julie Member Since: 07 Oct 2017 Location: Nantes Posts: 571 ![]() ![]() ![]() |
Mine's a MY2012, too. The oil pump has been replaced by a modified one. This has been done due to a recall from JLR in 2014 or so... |
Gloucesternige Member Since: 17 Jan 2020 Location: In the garage Posts: 114 ![]() ![]() ![]() |
I think you'll find the earlier, (and later replacement) pumps are geared pumps but the change in 2011 entailed fitting a vane pump? I believe also this can cause issues with oil starvation after an oil change as the pump will not self prime once drained. To answer the OP question.. it all depends how bad the damage is. I am currently rebuilding my 2.4 and am surprised how reasonable the prices of replacement bolts, gaskets, bearings etc are. If the engine seized I would suggest it could be scrap?? Nige Check out my You Tube channel https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel |
