Home > Puma (Tdci) > Think oilpump broken.. again...
TopQ1967
Netherlands 2012 Defender 130 Puma 2.2 HCPU Buckingham Blue
Hi
When my Defender 130 2.2 MY12 was 3 years old at 106.000 km. The oilpump broke and a new engine under waranty was fitted.
Now at 212.300km I think I face the same problem again.
I am just towed away.
Anyone else had this problem twice ?
Is there a way to clean everything or is the engine scrap now.
Regards
Quirin
Post #855822 13th Sep 2020 4:05pm
ickle
Shocked
Good luck!
Post #855832 13th Sep 2020 4:56pm
dazzling1611
United Kingdom 2011 Defender 90 Puma 2.2 HT Bronze Green
ive read somewhere that they changed the oil pump from 2011 and its prone to failing as the pump vains are some kind of plastic. The info ive found out is the earlier ones are much more reliable and fit the later engines.
Post #855977 14th Sep 2020 12:47pm
Julie
France 2012 Defender 110 Puma 2.2 SW Keswick Green
Re: Think oilpump broken.. again...
Mine's a MY2012, too. The oil pump has been replaced by a modified one. This has been done due to a recall from JLR in 2014 or so...
Post #856230 15th Sep 2020 10:41pm
Gloucesternige
United Kingdom 2011 Defender 90 Puma 2.4 HT Keswick Green
I think you'll find the earlier, (and later replacement) pumps are geared pumps but the change in 2011 entailed fitting a vane pump? I believe also this can cause issues with oil starvation after an oil change as the pump will not self prime once drained.
To answer the OP question.. it all depends how bad the damage is. I am currently rebuilding my 2.4 and am surprised how reasonable the prices of replacement bolts, gaskets, bearings etc are.
If the engine seized I would suggest it could be scrap?? Nige
Check out my You Tube channel
https://www.youtube.com/c/Defender90KeswickNigelsLandRoverchannel
Post #857245 21st Sep 2020 6:18pm
