- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
bankz5152
Huge thank you to Gareth at Empire Tuning! He retweaked my map until the CC worked properly
Cruise control can work if you have non standard ratios! Will make motorway run so much better Instagram @defender_ventures
Empire Tuning - Agent
23rd Dec 2020 4:19pm |
Chewyrab
Martin wrote:Black is the common input to both switches - connect this to the red cruise supply line from above diagram.
Blue is the "RES" (resume) output wire
Green is the "SET+" output wire
I can supply the 3 pin plug and terminals or crimped wires if you need.
For what it's worth I don't agree that that diagram is totally correct, it supplies 12V to the "brake off" input (pin 10) at all times when the cruise is switched on, when it should break to open circuit when the brake pedal is pressed. You can do this with a small changeover relay operated from the brake pedal output.
Afternoon gents. Does anyone have a schematic explaining the pin outs for brake 2 to show on diagnostics?
I have a stand alone loom on a series car and I've added cruise control but on diagnostics I cannot simulate the brake 2 switching.
Thanks.
28th Nov 2024 5:26pm |
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot vote in polls in this forum
