Home > Maintenance & Modifications > Td5 Provent 200 |
grafty99 Member Since: 15 Aug 2012 Location: North Devon Posts: 4793 |
Evening all!
I've just received my new Provent 200 from LRA. I've had a quick gander at mounting options but just thought I'd ask here to see if anyone has mounted one to a Td5 defender and if so, how/where did you mount it? I think the N/S wing support bracket looks like a good option as there is plenty of room and the pipe run would be very straightforward. I assume that to work correctly it needs to be level in both planes? Any experiences/thoughts greatly received 2002 90 Td5 Station Wagon 1990 Vogue SE Triumph Tiger Explorer 1200 Td5 90 Thread http://www.defender2.net/forum/topic50767.html Tdi 110 Thread https://www.defender2.net/forum/topic69562.html RRC Thread http://www.defender2.net/forum/topic54492.html Instagram http://www.instagram.com/george_grafton |
3rd Sep 2020 5:37pm |
ibexman Member Since: 13 Dec 2008 Location: Essex Posts: 2954 |
I have one George I’ll take pics tomorrow 👍
3rd Sep 2020 6:37pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Mine is mounted to a bracket on the heater box:
The height is quite limiting when you start trying to fit it in! 02' 110 TD5 Double Cab Rebuild Thread |
3rd Sep 2020 7:02pm |
I'm hoping for a cleaner intake tract from turbo compressor onwards 2002 90 Td5 Station Wagon
3rd Sep 2020 8:24pm |
Collects a surprising amount of oil. My intercooler and intake had quite a film of oil before i fitted the Provent. Since fitting it (12k ago) my intake has stayed clean so makes a big difference to this.
I never bothered connecting mine back into the sump, i just drain it out periodically. Steve 02' 110 TD5 Double Cab Rebuild Thread |
3rd Sep 2020 8:50pm |
blackwolf Member Since: 03 Nov 2009 Location: South West England Posts: 17536 |
If you see what comes out you won't want to put it back in your sump.
Click image to enlarge |
3rd Sep 2020 9:52pm |
mk1collector Member Since: 17 Sep 2009 Location: West Yorkshire Posts: 6772 |
I mounted mine on the wing bracket
Click image to enlarge Click image to enlarge I dropped a pipe with a tap down past the wing liner so I can empty oil out from under the wheel arch regularly and cleanly Ray My build thread http://www.defender2.net/forum/topic17615.html |
3rd Sep 2020 10:55pm |
Click image to enlarge Click image to enlarge Click image to enlarge |
4th Sep 2020 8:30am |
Perfect, thank you guys! I'm definitely liking the wing brace mounting option. I'll have a look at doing that later 2002 90 Td5 Station Wagon
4th Sep 2020 11:20am |
Just to wrap up the thread I've modified my wing stay bracket to accommodate the Provent. Just need to get some pipe ordered and it's another job done 2002 90 Td5 Station Wagon
4th Sep 2020 2:39pm |
kenzle8a Member Since: 12 Feb 2020 Location: None Posts: 1074 |
Is there a specific TD5 kit for this? Tempted to do mine as well.
4th Sep 2020 3:29pm |
I don't believe there is. Having said that you could fit one with very basic tools if needed 2002 90 Td5 Station Wagon
4th Sep 2020 5:45pm |
