Home > Maintenance & Modifications > Td5 Provent 200
grafty99
Td5 Provent 200
Evening all!
I've just received my new Provent 200 from LRA. I've had a quick gander at mounting options but just thought I'd ask here to see if anyone has mounted one to a Td5 defender and if so, how/where did you mount it?
I think the N/S wing support bracket looks like a good option as there is plenty of room and the pipe run would be very straightforward.
I assume that to work correctly it needs to be level in both planes?
Any experiences/thoughts greatly received Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Triumph Tiger Explorer 1200
Post #854089 3rd Sep 2020 5:37pm
ibexman
I have one George I’ll take pics tomorrow 👍
Post #854105 3rd Sep 2020 6:37pm
rallysteve
Mine is mounted to a bracket on the heater box:
The height is quite limiting when you start trying to fit it in! 02' 110 TD5 Double Cab Rebuild Thread
Post #854112 3rd Sep 2020 7:02pm
excossack
Does the provent make any noticible difference ? 1999 Defender TD5 110
Regards
John M0VAZ
Econet Station 48 no clock
Post #854130 3rd Sep 2020 8:11pm
grafty99
I'm hoping for a cleaner intake tract from turbo compressor onwards Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #854132 3rd Sep 2020 8:24pm
rallysteve
Collects a surprising amount of oil. My intercooler and intake had quite a film of oil before i fitted the Provent. Since fitting it (12k ago) my intake has stayed clean so makes a big difference to this.
I never bothered connecting mine back into the sump, i just drain it out periodically.
Post #854138 3rd Sep 2020 8:50pm
If you see what comes out you won't want to put it back in your sump.
Post #854157 3rd Sep 2020 9:52pm
mk1collector
I mounted mine on the wing bracket Thumbs Up
I dropped a pipe with a tap down past the wing liner so I can empty oil out from under the wheel arch regularly and cleanly Thumbs Up Ray
My build thread
Post #854167 3rd Sep 2020 10:55pm
ibexman
Post #854200 4th Sep 2020 8:30am
grafty99
Perfect, thank you guys! I'm definitely liking the wing brace mounting option. I'll have a look at doing that later Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #854219 4th Sep 2020 11:20am
grafty99
Just to wrap up the thread I've modified my wing stay bracket to accommodate the Provent. Just need to get some pipe ordered and it's another job done Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #854259 4th Sep 2020 2:39pm
kenzle8a
Is there a specific TD5 kit for this? Tempted to do mine as well.
Post #854267 4th Sep 2020 3:29pm
grafty99
I don't believe there is. Having said that you could fit one with very basic tools if needed Thumbs Up 2002 90 Td5 Station Wagon
1990 Vogue SE
Post #854286 4th Sep 2020 5:45pm
