![]() | Home > For Sale & Wanted > [Wanted] Defender truck cab glass or complete truck cab pane |
thepetrolhead Member Since: 30 Jul 2013 Location: South West Posts: 247 ![]() ![]() ![]() |
Just need some glass to fit back in. I need both corner curved bits of glass and the main rear window / sliding glass, which I assume is the same as the glass in the side panels?
Failing that, a complete Truck Cab panel. Does not need to be mint, as it is going into an off-roader to keep out the wet 🤔 Many thanks 👍 |
TVM
Oldowner Member Since: 26 Dec 2018 Location: South west Posts: 648 ![]() ![]() ![]() |
I think I have both sides of the rear sliding glass, I saved them in case I broke the rear window in my Hicap but it is long gone.
Thank you. Looking for complete unit if possible.
Otherwise I'll go down the perspex route for the rear window.. 👍 |
VVS210 Member Since: 12 Nov 2016 Location: Hampshire Posts: 953 ![]() ![]() |
The truck cab rear glass is not the same as the station wagon side windows, I can confirm that.
Somewhere I have the rear glass with the frame from a truck cab that I took out - will have a look at the weekend. |
bankz5152 Member Since: 02 Feb 2017 Location: South London/North Kent Posts: 2209 ![]() ![]() ![]() |
If its deffo the truck cab rear you need I have glass + frame complete.
Thank you
Where abouts in the south west are you?
PMs Sent to all that have replied. Thank you very much. Sincerely appreciated.
RuiPires Member Since: 12 Jul 2018 Location: Braga Posts: 19 ![]() ![]() ![]() |
Hi, I have for sale a complete rear window, with new felt, seal and one lock. Only needs another new lock. I am selling for 300€ plus shipping (from Portugal).
![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge ![]() Click image to enlarge |
