Home > For Sale & Wanted > [Wanted] Defender truck cab glass or complete truck cab pane
thepetrolhead
United Kingdom 2003 Defender 90 Td5 CSW Oslo Blue
Just need some glass to fit back in. I need both corner curved bits of glass and the main rear window / sliding glass, which I assume is the same as the glass in the side panels?
Failing that, a complete Truck Cab panel.
Does not need to be mint, as it is going into an off-roader to keep out the wet 🤔
Many thanks 👍
Post #854042 3rd Sep 2020 3:28pm
I think you'll find that the truck cab (or double cab) rear window is a completely different size to the normal side windows.
This was discussed some time ago in the context of fitting a gull-wing panel designed for a side window into the back of a cab, and the conclusion is that the two are completely different.
Post #854073 3rd Sep 2020 4:28pm
thepetrolhead
TVM Thumbs Up
Post #854077 3rd Sep 2020 4:58pm
Oldowner
I think I have both sides of the rear sliding glass, I saved them in case I broke the rear window in my Hicap but it is long gone.
Post #854141 3rd Sep 2020 8:54pm
thepetrolhead
Thank you. Looking for complete unit if possible.
Otherwise I'll go down the perspex route for the rear window.. 👍
Post #854238 4th Sep 2020 1:09pm
VVS210
The truck cab rear glass is not the same as the station wagon side windows, I can confirm that.
Somewhere I have the rear glass with the frame from a truck cab that I took out - will have a look at the weekend.
Post #854342 4th Sep 2020 9:40pm
bankz5152
If its deffo the truck cab rear you need I have glass + frame complete. Instagram @defender_ventures
Empire Tuning - Agent
Post #854356 5th Sep 2020 6:49am
thepetrolhead
Thank you Thumbs Up
Post #854379 5th Sep 2020 9:12am
bankz5152
Where abouts in the south west are you? Instagram @defender_ventures
Post #854384 5th Sep 2020 9:20am
thepetrolhead
PMs Sent to all that have replied. Thank you very much. Sincerely appreciated. Thumbs Up
Post #854385 5th Sep 2020 9:22am
RuiPires
Portugal 2003 Defender 130 Td5 HCPU Aintree Green
Hi, I have for sale a complete rear window, with new felt, seal and one lock. Only needs another new lock. I am selling for 300€ plus shipping (from Portugal).
Post #856566 17th Sep 2020 7:23pm
RuiPires
Post #856587 17th Sep 2020 9:07pm
