![]() | Home > Puma (Tdci) > Propshaft Greasing Points |
Raj23 Member Since: 30 Aug 2020 Location: East London Posts: 8 ![]() ![]() ![]() |
Hi guys
Just need some advice regarding propshaft greasing, I have a 2010 110 xs and managed to find and grease the Universal Joint grease nipples but cannot find any nipples on the shaft itself, I have used a telescopic mirror and checked with a fine toothcomb and there is nothing but the shaft, no holes ext, reading other related material there should be one on each of the front and rear prop but I think it was sent out the factory like this as I have owned it since new, any help would be greatly appreciated |
Thanks, now I can rest easy being a bit worrisome at times
Fat Cog Member Since: 19 Mar 2012 Location: Oxfordshire & Devon Posts: 502 ![]() ![]() ![]() |
Don't worry be happy...you're a Defender owner!!! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Dinnu Member Since: 24 Dec 2019 Location: Lija Posts: 3481 ![]() ![]() ![]() |
Mine, 2012 90 does not have greasing points on the sliding joint. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
