Home > Puma (Tdci) > Propshaft Greasing Points
Raj23
United Kingdom 2010 Defender 110 Puma 2.4 XS CSW Bonatti Grey
Hi guys
Just need some advice regarding propshaft greasing, I have a 2010 110 xs and managed to find and grease the Universal Joint grease nipples but cannot find any nipples on the shaft itself, I have used a telescopic mirror and checked with a fine toothcomb and there is nothing but the shaft, no holes ext, reading other related material there should be one on each of the front and rear prop but I think it was sent out the factory like this as I have owned it since new, any help would be greatly appreciated
Post #853142 30th Aug 2020 4:36pm
Fat Cog
Hi Raj...Some do & some don't...have nipples that is! If you cant see or feel them then dont worry. Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #853147 30th Aug 2020 5:54pm
Raj23
Thanks, now I can rest easy being a bit worrisome at times Smile
Post #853152 30th Aug 2020 6:06pm
Fat Cog
Don't worry be happy...you're a Defender owner!!! Since 1973...S1, Air Portable's, Defender's, but only my Wolf TUL HS GS remains
Post #853154 30th Aug 2020 6:12pm
Dinnu
Mine, 2012 90 does not have greasing points on the sliding joint. 1988 90 Hard Top, 19J Diesel Turbo, Shire Blue - Restoration ongoing
Post #853159 30th Aug 2020 6:39pm
