Home > 130 > Rear tub fixing
fatboyron
Rear tub fixing
Hello there I am just about to paint my rear tub with rapture paint.
Mine had a sheet of armoured ply in the bottom and it was pop riveted in and I've drilled out all the rivets and took out the ply and 6 bolts literally fell out. See picture.
Are these the actual fixings that hold the tub to the chassis or how is it fixed?
Post #852002 25th Aug 2020 7:48pm
jst
130 tub is fitted to rear crossmember via a bracket then uses bolts up from bottom into captive nuts that sit in a sleeved section that runs parallel to crossmember that is attached to the bottom of tub.
Front of tub fits via bolts to cross pieces in front of rear wheels. Cheers
James
110 2012 XS Utility
130 2011 M57 bespoke Camper
90 2010 Hardtop
90 M57 1988 Hardtop
Post #852009 25th Aug 2020 8:17pm
fatboyron
thanks jst for your reply so it's all attached from underneath I couldn't get under yesterday because we're I jet washed it out it was just crap everywhere on the floor
Post #852063 26th Aug 2020 7:13am
jst
Correct, all from underside Cheers
James
110 2012 XS Utility
90 2010 Hardtop
90 M57 1988 Hardtop
Post #852249 26th Aug 2020 8:33pm
