Home > 130 > Rear tub fixing |
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8152 |
130 tub is fitted to rear crossmember via a bracket then uses bolts up from bottom into captive nuts that sit in a sleeved section that runs parallel to crossmember that is attached to the bottom of tub.
Front of tub fits via bolts to cross pieces in front of rear wheels. Cheers James 110 2012 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
25th Aug 2020 8:17pm |
fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116 |
thanks jst for your reply so it's all attached from underneath I couldn't get under yesterday because we're I jet washed it out it was just crap everywhere on the floor
26th Aug 2020 7:13am |
Correct, all from underside Cheers
26th Aug 2020 8:33pm |
