Home > Maintenance & Modifications > Damaged MAF Connector Wiring |
I was mooching around the engine bay yesterday (as you do) and noticed that the insulation on the wiring to MAF connector was damaged:
Click image to enlarge I guess it's vibration fatigue as the wiring isn't particularly tight. There are no obvious issues yet but I'd obviously like to repair it. Does anybody know where I might be able to source a new plug and pins so that I can remake the connection? I may also look at something to better support the wiring Darren 110 USW BUILD THREAD - EXPEDITION TRAILER - 200tdi 90 BUILD THREAD - SANKEY TRAILER - IG@landroveranorak "You came in that thing? You're braver than I thought!" - Princess Leia |
24th Aug 2020 4:08pm |
rallysteve Member Since: 10 Feb 2014 Location: Cumbria Posts: 2238 |
Think this is the one:
https://kojaycat.co.uk/epages/950000457.mo...cale=en_GB Steve 02' 110 TD5 Double Cab Rebuild Thread |
24th Aug 2020 4:10pm |
Blimey, that was quick! Thanks Steve, now ordered Darren
24th Aug 2020 4:27pm |
Whilst trawling through old posts about this issue, I noticed that Martin now sells these connectors through the forum shop, including pre-wired versions! I've now ordered one of those instead as the extra cable will help with doing something clever with routing to prevent it happening again. Darren
25th Aug 2020 8:01am |
