- You are currently viewing DEFENDER2.NET as a guest - Register to take part or Log In
Sicastle71
Check injectors by loosening the nut at the top of each injector in turn repeat the throttle up at each injector loosening. If white smoke stops when one is loosened their is your duff injector
27th Aug 2020 1:51am |
