![]() | Home > Technical > Odyssey (dead) and CTEK |
NinetyTD4 Member Since: 22 Apr 2011 Location: North Posts: 397 ![]() ![]() ![]() |
Didi you check the correct setting of the chargers? If I remember correct, PC1500 are AGM batteries and not standard lead acid. If you charge with the wrong characteristics and/or without proper temperature sensors, you may cook them. Put a voltmeter for monitoring and check the max voltage at the given ambient temperature does not exceed the manufacturers specs! Never forget: cars have owner, Landrover have field service personnel.
jst Member Since: 14 Jan 2008 Location: Taunton Posts: 8208 ![]() ![]() ![]() |
Steve, the odyssey quality has slipped of late in my experience, i think there are now better options out there. i have an odyssey 5years old running an L322 no problem. had two others in defenders that would be 3 years old this year except they were scrapped last year as wouldnt hold charge. they are not a battery i would purchase. Cheers
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 290 ![]() ![]() ![]() |
It does seem to be that way.... one is fine the other is on charge at the mo so will see what happens. @steve_overland on Insta.
110 expedition vehicle with pop roof |
It would appear that the odyssey is Definitely dead... anyone have any recommendations that would fit in the same spot under the seat next to the other one.... @steve_overland on Insta.
Joe the Plumber Member Since: 18 Dec 2013 Location: Midlands Posts: 921 ![]() ![]() |
There's only one place worth looking at for battery stuff:
http://www.aandncaravanservices.co.uk/ And remember that Yuasa L36-EFBs are also sold by Halfords as HLB700s, which are much cheaper if you've got a Trade Card. |
Tayna.
Cxv27mf numax, 2of them fit in battery box. Sell other odyssey it will pay for both these. Cheers James 110 2010 XS Utility 130 2011 M57 bespoke Camper 90 2010 Hardtop 90 M57 1988 Hardtop |
Tompoole Member Since: 05 Jun 2011 Location: Bucks Posts: 828 ![]() ![]() ![]() |
make sure the odyssey isn't receiving a charge of over 15v it will kill it check ctek profile is correct agms need 14.7 to charge to 100% is it wired for agm ?
, are you running a solar panel through ctek or through an independent mppt like a victron? again check profile and set to aGM with equalisation off I run two oddesy and one optima yellow top on 110 and two yellow tops on 90 without any issues as yet , but voltage never above 14.7v when charging.... Odyssey's run fridge 24/7 on 110. Have fun be happy |
Hi there Ctek was set to normal so 14.7... solar is through the Ctek dual battery and smartpass ... @steve_overland on Insta.
