Home > Technical > Dab on a roof rack CB aerial??
Page 2 of 2 <12
Steve_overland
United Kingdom 1997 Defender 110 300 Tdi HT Chawton White
Sorry I didn’t realise this was to a cb aerial... Will look at the link you sent @steve_overland on Insta.
110 expedition vehicle with pop roof
Post #849965 14th Aug 2020 3:55pm
Tribord
France 2011 Defender 110 Puma 2.4 XS DCPU Zermatt Silver
Steve_overland wrote:
I just don’t want to drill a hole in the wing... and already have a hole in the leg on my solar panel so makes sense to fit it there ...
If you don't want to drill the wing, you can go through the wing top vent cover, either the standard plastic one, or one like I now have, below. You then also have the benefit of an easy route into the engine bay or cockpit without having to hide the cable. Has worked well for me.
Post #850206 15th Aug 2020 8:12pm
Steve_overland
Ah is that a digital aerial....how did you earth it? @steve_overland on Insta.
Post #850256 16th Aug 2020 6:59am
Tribord
It just uses an antenna cable direct to a vhf transceiver installed in the cubby box
Post #850292 16th Aug 2020 10:33am
Steve_overland
Ah ok... it’s a dab mount like this I’m trying to understand?? Or if possible convert a cb aerial to work on dab. @steve_overland on Insta.
Post #850302 16th Aug 2020 11:25am
Page 2 of 2 <12
