![]() | Home > Technical > Dab on a roof rack CB aerial?? |
Tribord Member Since: 20 Apr 2013 Location: France Posts: 220 ![]() ![]() ![]() |
If you don't want to drill the wing, you can go through the wing top vent cover, either the standard plastic one, or one like I now have, below. You then also have the benefit of an easy route into the engine bay or cockpit without having to hide the cable. Has worked well for me. ![]() Click image to enlarge |
Steve_overland Member Since: 14 Oct 2018 Location: Gaydon Posts: 290 ![]() ![]() ![]() |
Ah is that a digital aerial....how did you earth it? @steve_overland on Insta.
110 expedition vehicle with pop roof |
It just uses an antenna cable direct to a vhf transceiver installed in the cubby box
Ah ok... it’s a dab mount like this I’m trying to understand?? Or if possible convert a cb aerial to work on dab. @steve_overland on Insta.
