Home > Technical > Puma cigar lighter
fatboyron
Puma cigar lighter
Hello everyone what it is I've just bought a new cigar lighter to put in my puma and I've taken the centre console out to fit it and I've got the little white socket to go in for where the light is but I've got the wires to go in the other one but there's no socket on it can I buy that socket separately and does anyone know the part number the second pics from a TD5 I've got a from internet I think that's the one I need hope someone can help
Post #849375 11th Aug 2020 7:56pm
macfrank
Hi, part no is AFU3199
https://www.lrworkshop.com/connectors/defender-2007/C0089
If you can't find it, I'd suggest you crimp two separate connectors.
Just need to make sure to get polarity right! Black is ground, of course.
p.s. remove fuse 26 (20A) while working on the wires
Post #849464 12th Aug 2020 9:49am
Martin
Site Admin
Can you just clear up which bit you need? I can't make out from your description and photos what you are missing or trying to achieve?
Martin  1988 90 Td5 NAS soft top
2015 D90 XS SW
Post #849467 12th Aug 2020 10:07am
fatboyron
Thank you mac that's the part I'm after. I'll give duckworth a call later ackworth again thank you both for your replies and I do love this forum for the knowledge
Post #849542 12th Aug 2020 2:56pm
Martin
Site Admin
Ah OK if you're after the black 2 pin plug AFU3199 then I can supply you one - they aren't available from LR.
I use them to make the piggy back wiring looms for D3/RRS heated steering wheel supply.
2015 D90 XS SW
Post #849545 12th Aug 2020 2:59pm
fatboyron
Hello Martin you are right land rover don't supply them I just got off the phone with them I'll p.m. you
Post #849561 12th Aug 2020 3:49pm
