![]() | Home > Technical > Puma cigar lighter |
macfrank Member Since: 05 Nov 2015 Location: somewhere in the north Posts: 1105 ![]() ![]() ![]() |
Hi, part no is AFU3199
https://www.lrworkshop.com/connectors/defender-2007/C0089 If you can't find it, I'd suggest you crimp two separate connectors. Just need to make sure to get polarity right! Black is ground, of course. p.s. remove fuse 26 (20A) while working on the wires |
Martin Site Admin Member Since: 02 Apr 2007 Location: Hook Norton Posts: 6645 ![]() ![]() ![]() |
Can you just clear up which bit you need? I can't make out from your description and photos what you are missing or trying to achieve?
Martin ![]() ![]() |
fatboyron Member Since: 28 Jul 2018 Location: Aylesham Canterbury Kent Posts: 116 ![]() ![]() |
Thank you mac that's the part I'm after. I'll give duckworth a call later ackworth again thank you both for your replies and I do love this forum for the knowledge
Ah OK if you're after the black 2 pin plug AFU3199 then I can supply you one - they aren't available from LR.
I use them to make the piggy back wiring looms for D3/RRS heated steering wheel supply. ![]() Click image to enlarge ![]() ![]() |
Hello Martin you are right land rover don't supply them I just got off the phone with them I'll p.m. you
